Disc Harrow Stuck wheel hub/bearing cover (?) on a JD KBA disk
   / Stuck wheel hub/bearing cover (?) on a JD KBA disk #1
Thump1
Hinsdale, IL
JD 4500
Okay guys I'm embarassed to have to ask this one. I bought an old KBA that has been sitting for many years. The wheels turn smoothly and I can get the lug nuts loose but zero luck on either side getting the outer wheel bearing cover (I think) off. I'm just short of heating with a torch but don't want to fry the thing if this is just one more example of my ignorance. Thanks in advance. Steved
   / Stuck wheel hub/bearing cover (?) on a JD KBA disk #2
It's just pressed on, should be able to take a blunt nose chisel and work around the cap to get it to start moving.
   / Stuck wheel hub/bearing cover (?) on a JD KBA disk #3
An alignment tool with a hook on one end is what I use. Hammer it in the groove and you have enough leverage to twist it as you hammer. Then turn wheel and do another spot. It will eventually come loose. Then a big pair of channel locks and finish pulling or twisting it out.
Thanks Gentlemen,
Very helpful. I had the right idea but was being too gentle. I now have the go ahead to apply the appropriate amount of force to the situation:D
   / Stuck wheel hub/bearing cover (?) on a JD KBA disk #5
Understandable. :) always easier to ask than to damage a part. I have a 7.5 foot KBA and really like it. Good luck with yours.
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
Mini Skid Steer Sweeper Attachment (A51573)
Mini Skid Steer...
2011 PETERBILT 389 (A52472)
2011 PETERBILT 389...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
