Stuck throttle
   / Stuck throttle #1
CBCGC1715
MF GC1715
Just started my tractor up it's a gc1715 and my throttle is stuck. Is there something I'm missing? It worked perfectly fine two days ago?
Please help it only has 92hr on it.
   / Stuck throttle #2
How cold is it by you? Might there be water in the control cable from rain or pressure washing? That could freeze and immobilize the control.
   / Stuck throttle
5 degrees and I bet you are right.
   / Stuck throttle #4
Great, I hope it’s something cheap and simple to fix. Beware of using flame to remedy this.
A light bulb or hairdryer applied for 20 minutes or more, might restore your joy.
Let us know,OK?
   / Stuck throttle
I used white lithium and sprayed it within the liner. It worked!
I plan on injecting antifreeze within tomorrow.
   / Stuck throttle #6
I am a fan of graphite powder in situations like this.
Hopefully the lithium and/or antifreeze won’t dry out or form some gunk/sludge that could cause problems way down the road.
   / Stuck throttle #7
Gotta love those easy fixes.
Throttle froze once on me I use antifreeze spray you can spray windshield.
   / Stuck throttle #8
Umm, there should not be any way moisture to get in throttle cable other than condensation... Might look a bit at how throttle cable is mounted and if there any dist/moisture caps on sleeve that may need replacing...
Dale
   / Stuck throttle #9
I will keep a eye on mine this winter being it is in a unheated shop/garage although I have been using my Kerosene heater awhile before I try starting it these last few weeks, is it also possible to blow some air thru the cable to blow out any condensation? I will poke at mine next time I go out to the shop.
   / Stuck throttle #10
The way the cable is mounted on GCs, rain can get into the cable at the top from sitting on the dealers lot. Run a hair dryer along the line. It's likely frozen up on the underside where water can collect. Inject the line from the top with a mix of diesel and antifreeze until that mixure pushes through the bottom of the cable.
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
