Stuck Throttle / Governor?
   / Stuck Throttle / Governor? #1
wgbiii
My neighbor just called me with a problem with his 1980+/- JD750. He went to start it up for the 1st time in close to a year and as soon as he started it it went to full power. When he finally got it to shut off (by running out of fuel) he inspected the throttle linkages and everthing appears to be working correctly. He started it up again and the same thing happened. This time he had to run into something to get it to shut off since the fuel cutoff was stuck.
Any ideas as to why it is running at full power and any suggestions as to how to fix it would be greatly appreciated.
Thanks,
Will
   / Stuck Throttle / Governor? #2
If nothing is found sticking in the linkages, then it's in the injector pump.
A soft rap with a rubber mallet on the side of the pump might dislodge the stuck rack. It only work once out of the 3 stuck pumps I've worked on, the other two I had to disassemble, clean and reassemble.
If you have never done any injector pump work before, get a shop manual or somebody that knows what they're doing.
Working on a injector pump is not to be taken lightly.
JOHN DEERE 6615 TRACTOR (A51247)
JOHN DEERE 6615...
2020 International MV607 2,000 Gallon Water Truck (A51692)
2020 International...
Year: 2019 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 177,369 Plate: Body Type: Cutaway (A51692)
Year: 2019 Make...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
UNUSED GREAT BEAR FORKLIFT JIB (A51248)
UNUSED GREAT BEAR...
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
