Stuck Quick Connect
/ Stuck Quick Connect #1
dkhunter
I recently had a plow installed on my RTV. I am trying to remove the plow and one of the hydraulic quick connects is stuck. I can not get the female sleave to push back to remove the hose. The other connections came off fairly easy. Is there any tricks to this? Any suggestions would help.
Thanks
/ Stuck Quick Connect #2
Have you tried operating the lever while the engine is off to eliminate built up pressure?
/ Stuck Quick Connect #3
If after you've done what Kenny said to do and it still won't work, you may have to destroy the connector to get it off !! It was about 4 years before I went to remove my loader for the first time and all 4 of mine were corroded bad enough that I had to destroy them and buy new ones. You can bet I doped them up good with antiseize when I installed the new ones. Pull back on the sleeve and coat the balls and all contact points really good with it and work it back & forth a few times before reconnecting a hose to it. I also put some on the male end in the groove where the balls engage but was careful not to get it on the portion that slips into the "O"ring in the female side. Hopefully your problem is just the pressure build-up. Also note that warmer air temps and/or direct sun will build pressure in a disconnected hose - sometimes you have to release this pressure before you try to reconnect the hose or it won't go. I usually wrap the hose end with a rag and bump the tit with a piece of wood or rubber hammer to release the pressure.
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2015 FREIGHTLINER M2 6X4 T/A  24FT FLATBED TRUCK (A59914)
2015 FREIGHTLINER...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
2024 DODGE TRUCK BED (A65643)
2024 DODGE TRUCK...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
