Stuck PTO shaft
/ Stuck PTO shaft #21
A 50/50 mix od Acetone and ATF is the most potent solvent I have ever used, Kroil is next. If you try this mix, it must be stored in a metal or glass (not recommended) container.
/ Stuck PTO shaft
Thanks to all on your suggested tips. I inverted the shaft and sprayed wd40 and carb cleaner down between the two shafts. It eventually made its way down in . I then chucked one end of the shaft in a Vice, but loosely so i could slide the whole setup like a slide hammer. It finally came loose after about five good slams.
/ Stuck PTO shaft #24
I use Fluid Film. No problems after 8 years in this wet-then-dry climate.
Bruce
/ Stuck PTO shaft #25
So what do you use on the PTO shaft? Grease, used oil?
EVERY time I'm going to use the tractors pto shaft, I spray it with wd40, then I spray wd40 into the female half of the pto shaft and work it back and forth a couple times. I also spray the locking button or collar on the yoke and make sure it's free.
This makes hookup MUCH easier and the wd40 evaporates, leaving things dry enough so they don't collect dirt, everything works just fine the next time I need it...
I store them apart and that's it, until I use that tool again...
SR
/ Stuck PTO shaft #26
To the guy who used his PTO to pull the telescoping shaft apart:
BE CAREFUL! Most PTO shafts are held into the tractor by a snap ring or other not-so-robust means. Don’t pull hard on this or you will have some strange, expensive-looking oily parts fully visible behind the tractor.
Even the whole casting that holds the PTO output bearing and seal has been known to fracture when a shaft puts end pressure on it.
PS. Rereading this, it may be that repowell unhooked the shaft from the tractor and got the tractor out of the way, not used it to pull the stuck shaft apart.
/ Stuck PTO shaft
I finally got this thing apart. The grease on the internal shaft was like baked hard carbon. I ended up cleaning it, and used a final pass with a flap sander wheel. So what is the best lubricant to use?
/ Stuck PTO shaft #29
One other thing to be aware of.... I had the same problem with the shaft on my Woods 990 mower for years. Did all the above plus checking for burs and bumps on the shaft ends.
It would still get stuck on a regular basis, usually about an inch or two from enough length to put it on the PTO shaft of the tractor.
I finally discovered it was the safety shield tubes around the shaft. So now I squirt some PCL or other thin lubricant where they slide together before pulling the shaft out and it works perfectly.
/ Stuck PTO shaft #30
NONE, until you are putting it together, then spray it with wd40...
It's NOT a bearing, it moves very little in use...
SR
/ Stuck PTO shaft #31
The PTO shaft on my brushhog is frozen and won’t extend. I’ve soaked it in both PB BLASTER and WD40. Anyone
got any tricks up your sleeve to get these unstuck?
I had the same problem with a rotary cutter shaft. I sprayed the heck out of it with PB Blaster and was able to pull it apart with the tractor. I then cleaned both ends by soaking the in degreasing solvent, dried everything and completely coated the male end with anti-cease and haven’t had any more problems with it. Maybe this will will work for you too. Good luck!
/ Stuck PTO shaft #32
So, it NOT just my auger ! I had this challenge last week, will need to grease it a bit I guess.
They make it look so easy in the instructional videos ... never a glitch. :)
/ Stuck PTO shaft #33
Popular Mechanics Magazine had an article 20 years ago that tested many solutions for breaking rusted objects free. It's a simple 50/50 mix of Acetone + Automatic Transmission Fluid.
My radial arm saw always cranked up and down with extreme difficulty, though it never seized. I poured the acetone/xmission fluid mix down the radial arm shaft and half an hour later it was cranking like a dream. It works wonders on seized rusty nuts and bolts. It was far better than all the commercial sprays for rust fixes in the Popular Mechanics test.
Good luck with your PTO shaft.
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
84in. Snow or Litter Skid Steer Bucket (A65640)
84in. Snow or...
Cultamulcher (A66408)
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Golf Cart (pictures to come) (A62679)
Golf Cart...
2016 WESTERN STAR 4700SF DUMP TRUCK (A59914)
2016 WESTERN STAR...
