Stuck Pin? Hydralics Question
/ Stuck Pin? Hydralics Question #21
timcote42 said:
By the way, any guesses on what your standard 1"x4.25" pin will cost? They're drilled for cotter pins. Think they're heat-treated for hardnes? My guess is $20ea. Winning guess gets a cupie doll! Tim
TractorSmart has them for $19.01 each +shipping ;)
/ Stuck Pin? Hydralics Question #22
timcote42 said:
I tried the "wack the **** out of it" advice and they barely moved.
Tim
Did you properly support the underside like I suggested?
/ Stuck Pin? Hydralics Question #23
Did you ever get these pins out? How did the repack go? My swing cylinders are looking more and more like they need a repack... might be a good winter task.
Charles
Charles
Charles,
Just back from trip to Europe for work, next step it to cut 'em with the angle grinder, then remove cylindar, order all stuff for repack and new pins. I will get my kid to phoro to spark spray. Work and Christmas and the cold are obsticles as great as the stuckness of the pins, but I shall prevail!!!!
/ Stuck Pin? Hydralics Question #25
I have had pretty good luck using an air chisel to knock things like pins out. I cut the end off of one of the chisels so I had a flat end to drive with. The vibration will loosen rust and you don't put nearly as much strain on things as you do when whacking with a big hammer.
It also helps if you can put something under the fitting to hold it solid while tapping away. If you are trying to drove the pin out with no support under the arms the arms are absorbing most of the force and you can bend them. I usually use a deep socket that is larger than the pin under the arms so the pin can slide into the socket.
I hope that makes sense.
BTW, you can buy an air chisel at Harbor Freight or Lowe's for less than $25.
Thanks Bill, an air chisel sounds like a good investment. Next time I'm at harbor freight, I'll add one to my collection of cheap and useful tools.
The saga of the stuck pin goes on. Today I followed the plan, cut the bottom of the pin and extracted the cylindar. The remaining portion of the pin is still badly stuck in the cylindar, but at least it's out, ready for me to attack with the 10 ton bench press.
But before I do, I started to inspect this extracted swing cylindar, origionally removed because both were leaking, and noted that the ram has a bit of a chunk taken out of it from the previous user.
QUESTION: Should this cylindar be repacked or replaced? If replaced and I was planning to repack the other one too, should I replace it's sister? One advantage to replacement is it would make it less necesary to try and get this darn pin completely out.
This is turning into a major job. Please tell me not everything will be so.....
Tim
/ Stuck Pin? Hydralics Question #27
Take the cylinder to a local Hydraulics shop. If you don't know of one, stop by a construction equipment dealer and ask. It can probably be repaired. There is no need to replace both cylinders if only one is damaged. Balance, etc. is not a concern.
This is a very good idea---restore don't replace. I just checked tractor smart...they want $430 for each cylindar!!!!! Yikes! So....should the ram be replaced too? Will that nick tear out the packing quickly, making for another leak?
/ Stuck Pin? Hydralics Question #29
Take it to a hydraulic shop, they can fix it for a fraction of replacement cost, and they can press out the pin as well!
Okay folks, here's the follow-up on this story that is taking much much too much time and energy. I finally cut off the second pin, extracted the second leaking cylindar, and see that it too has a (smaller) nick in the ram. Tried to drill out the pin per my dad's instructions and only managed to make a pin with a lot of holes in it and several dull drill bits.
Brought it in to the hydraulics shop today. They say the nick is not a problem except that it will leak when that nick sits directly on the seal, but since that should be momentary it's probably not worth buying a new ram at $150. They will try to press out/drill out these extrodinarilly stuck pins and will repack the cylindars after smoothing the nicks so it won't tear the new seals, will also bead blast and repaint. Cost: $130/cylindar or $260 to have them "good as new" (sorta).
After all this aggrivation, I said "sure". Hopefully this will be my last post on this topic, unless they have some major issue with getting the stuck pins out .....Tim
/ Stuck Pin? Hydralics Question #31
Good choice! Good hyd shop [truth not bs]. Dont lose track of these guys!
larry
Thanks to all for this long oddesy. finally got up to Baltimore to pick up the hydraulics and the pleasent surprise was that the bill was only $180 total. Two cylindars repacked and the pin knocked outa the housing, hooray.
Now, before my re-install of these swing cylindars I was told by the previous owner that there's a "bad bushing" in the main pivot. I suppose this will require further disassembly to try and figure it out.
By the way, I went and bought a sandblaster in the hopes of doing a steady piece-by-piece repaint of this backhoe, loader and the tractor itself. I now see that without a blast chamber I am going to loose lotsa $ in grit by just blasting stuff in my driveway.
The architechts have finished the preliminary conceptual drawings of my rear addition and the county has approved the plat, so my cheif justification for buying the tractor ("I can do that excavation myself and save lots of money.") is near at hand. Perhaps the re-paint should wait until after all that work is done......
Pics to follow as I tear into the thing....
Oh, by the way, on the repacked cylindars it is now impossible to move the ram in and out by hand. I am told this is because of the tight seal the new seals make against the cylindar wall, and that once filled with fluid all will be well. Any confirmation of this from y'all?
/ Stuck Pin? Hydralics Question #35
When I installed new top'n tilt cylinders, they couldn't be budged at all by hand. Hooked them up and they work exactly like they are intended.
