Stuck on hydraulic filter
/ Stuck on hydraulic filter #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
After reading many horror stories of guys removing their hydraulic filters, I was prepared. I bought these chain vice grips. Locking Chain Clamp
Had absolutely no problem with either the hydraulic or hst filter. The hydraulic filter was really on there too.
/ Stuck on hydraulic filter #2
Cheaper and just as effective is the type that looks like a seat belt on a 4 inch long steel tube. The inside of the tube gives you a place for your 1/2 ratchet or breaker bar. Simple and works on all sizes of filter cans. No cutting or crushing of cans. Both good tools.
/ Stuck on hydraulic filter #3
I had no luck with this type and as a last resort, purchased the chain type that did work, as the OP mentioned.
/ Stuck on hydraulic filter #4
Yup, the HF locking chain wrench the OP links to will do the trick. If you need more leverage the first time around, a 12" section of 2" sch 40 PVC pipe will fit over the grips and amp up the force. If the canister starts to crush before popping free, reposition the chain. The nearer the thread end the better. Too much concentrated force can cut into the can.
/ Stuck on hydraulic filter #5
... If you need more leverage the first time around, a 12" section of 2" sch 40 PVC pipe will fit over the grips and amp up the force...
I use PVC sch 40 pipe as an extension for almost anything, including the 3/4" ratchet and breaker bar. I also have various lengths and diameters of metal pipe if needed, but they are heavy in the larger diameters.
/ Stuck on hydraulic filter #6
I used a different type chain wrench that works with 1/2 drive. I used an extension and breaker bar and I needed every ft/lb of it. It crushed the filter a little but no leak.
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
2016 CHEVROLET SILVERADO 3500HD DUALLY (A65643)
2016 CHEVROLET...
2022 EZ-GO ELITE...
MAGNUM LIGHT TOWER (A65643)
MAGNUM LIGHT TOWER...
Farm Star 3Pt Bale Spear (A66408)
Farm Star 3Pt Bale...
