Stuck in fwd
/ Stuck in fwd #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
I have a M4900 cab tractor with syncro-shuttle that I put in reverse and now it won't come out of rev. If the 2 speed selector and the 4 speed selector are both in neutral and I put shuttle in fwd it loads engine. It will back up in all gears. I checked shuttle shift linkage and it all appears in working order to the clutch housing. I've owned tractor for 4 yrs and it has 1452 hrs on speed/hr meter. I'm stumped. Thanks for any ideas,Jim
PS I posted this on the General forum and then decided this Forum would be more appropriate.
/ Stuck in fwd #2
Will the gear selector not go into forward, or will the gear selector go into the forward but the tractor does not respond? We had a NH one time that could not shift between gears, the dealer told us the clutch plate was corroded from mud. He cleaned it up and it worked again. Since then, we have kept the clutch plate pressure washed and it has worked fine.
/ Stuck in fwd #3
I had an M4700 that the linkage below the selector would jump out and not go into neutral. I had to get underneath and operate it to clear it. Maybe you have a similar problem?
Ken
/ Stuck in fwd #4
You are definitely showing to be locked in two gears at once! Reverse is where you are at!!!!
/ Stuck in fwd
I split between between engine and clutch housing,removed shuttle shift assembly and upon dis-assembly I found reverse synsonizer bad.
ROME RLS12 HYD SCRAPER (A63276)
ROME RLS12 HYD...
2003 Freightliner MC 331 2,800 Gallon Fuel Truck (A64194)
2003 Freightliner...
(2) RIMS FOR 10 LUG HUBS (A64278)
(2) RIMS FOR 10...
Killbros Mod. 385 Gravity Wagon (A66285)
Killbros Mod. 385...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
