stuck fuel filter jinma 354
   / stuck fuel filter jinma 354 #1
gergstuff
Ferndale, WA
Jinma 354
I was trying to replace the fuel filter on my recently aquired jinma 354. I cannot get it to budge. The mount the spin on housing is attached to is bending. I suspect it is rusted on there as the tractor has been sitting outside with little use for 6 years.
Any ideas on how to get it off withoutbreaking something would be appreciated!
Craig
   / stuck fuel filter jinma 354 #2
I had that problem also at my first filter change. Had to remove the filter and head assembly from the tractor and put it in a vice and use a chain wrench. The filters don't have to be that tight. When you reinstall it put a film of lube oil on the seal surface where it contacts the filter head.
   / stuck fuel filter jinma 354 #3
Given the presence of engine oil, I doubt it's rust. The more common problem with these is paint. Rather than paint the block before assembly, they spray the whole **** thing as it goes out the door. I got mine off by driving a screwdriver through the filter canister then putting a cheater pipe on the screwdriver handle. You'll likely have to do the same thing with the fuel filter.
//greg//
   / stuck fuel filter jinma 354 #4
Craig
I had the same problem with my 304, and I removed the entire housing and took it to my vise, and then I got right aggressive with it.
   / stuck fuel filter jinma 354 #5
Same here for me, Mine (JM284) was right at the point of bending my bracket which is started a bit. I stopped took a small rubber hammer and tapped the (;@p out of it. I put filter wrench back on and still started to bend a bit. At that point I used ball peen hammer and a round bar to ding the top edge some. still would not come loose so I got a dull flat chisel and hammered the top edge about 1/3 way around in a knock it loos direction which got it off. It did break the filter and spilled fuel in the process the thing came off though...
Mark
   / stuck fuel filter jinma 354 #6
uuuh, is the filter a spin-on, or is it held in place by a small bolt down thru the top of the bracket?
   / stuck fuel filter jinma 354 #7
I had trouble, Ron, and mine was a spin on. There is a bleed bolt at the top, but it is only a spin on filter on mine.
   / stuck fuel filter jinma 354 #9
For the spin on's a long screwdriver, a smaller chisel and a good hammer f
Should do the job.:thumbsup:
Course if there is room a long handle will Work wonders. :D
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51246)
2005 KOMATSU...
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
