stuck collar
/ stuck collar #1
wedge40
I needed to swap grapple and bucket and when I went to pop the QD's one of the collars would not budge. It was NOT pressure since I had removed the connection completely. I ended up using a screw driver to push the collar far enough back so it would disconnect from the hose. Is this a messed up QD that I need to replace or is there something I can do to fix it.
I see a snap ring on the end or what looks like a snap ring. If I take this off can I take the QD apart and clean it up. Or should I just get another QD.
:confused:
Wedge
/ stuck collar #2
Wedge...
Dirt, dust, sand about anything can get under the sliding collar and keep it from moving. Lightly rapping it with a chunk of wood, (hammer handle) should allow it to free up. Then spray it out with WD40. Try coupling and removing again... KennyV
/ stuck collar
Wedge...
Dirt, dust, sand about anything can get under the sliding collar and keep it from moving. Lightly rapping it with a chunk of wood, (hammer handle) should allow it to free up. Then spray it out with WD40. Try coupling and removing again... KennyV[/QUOTE
Already done that Kenny. I sprayed WD-40 in there and twisted the collar. It took a pipe wrench and cresent wrench to twist the collar. I think I'm going to just order a couple form DHH, and then I'll tear this one apart to see what happened.
Wedge
/ stuck collar
Upon closer inspection, the title should read. "Cracked Collar"
Wedge
/ stuck collar
your right... if it's cracked it will jam...
I wonder how it got cracked? I guess I really need to get the QD mount plate done so the hoses aren't just hanging around.
Wedge
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2005 Freightliner FLD120 Ambulance (A66736)
2005 Freightliner...
2006 Heil DOT 406 9,500 Gallon Comp T/A Fuel Tanker Trailer (A68183)
2006 Heil DOT 406...
2021 CID POTSS Skid Steer Quick Attach Conversion Tractor Attachment (A66734)
2021 CID POTSS...
2014 CHEVROLET CAPRICE (A66091)
2014 CHEVROLET...
PALLET OF HOSES (A68842)
PALLET OF HOSES...
