M5farms
Platinum Member
- Joined
- Sep 1, 2014
- Messages
- 804
- Location
- Panhandle
- Tractor
- jd 2630 - NH TL100A-35 ferg-53 ford backhoe
I had every barn torn down in hurricane so I have not been able to park the tractors under cover for over a month . My NH tl100 does not have a loader yet (it will be in next week) so it has seen limited use during clean up. I used it a couple weeks ago to drag some large logs and trees and it sat for 2 weeks , during that time we got about 7" of rain and when I went to put it under the new barn I built last weekend it would not go into gear while running. I had a stuck clutch a couple of years ago and symptoms were the same and previous time it was a simple remedy of just driving it a few minutes .
I tried that again and no luck . I tried hitting the brakes , starting in gear , putting against a tree , pulling logs and still no luck. talked with a couple of mechanics and all recommend what I had tried . I Cut a block on monday and left clutch depressed for 2 days . yesterday I backed it out from under the barn with intentions of hooking it to the bottom plow and plowing till something broke. I decided one more try on getting it in road gear was warranted . I got the usual resistance when trying to push it in but this time it didn't start creeping like before and all of sudden it just fell in gear. nothing broke and works like it should . I did however block the clutch just to make sure .
