Stuck clutch fixed.
/ Stuck clutch fixed. #1
footloose
Ih D40
IH D40 clutch stuck after parked a bit.
Last time this happened I spent 5k for a new clutch.
I had no clutch after parked in weather a while.
I oozed it to a sloped back driveway and put my f150 in front.
I tried yanking with clutch blocked.
I heated it up by 30 min high idle.
Tried again no luck.
Gave up, it cooled down, 3rd yank afterwards worked.
Tractor in high gear, clutch pedal blocked down, small yanking up hill with truck.
Good luck!
From now on I'll park it with clutch blocked off the flywheel.
/ Stuck clutch fixed. #2
Welcome to TBN.
Not sure of your setup,place small piece of notch wood between under foot step against clutch pedal shaft.
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2019 Ram 4500 4x4 S/A Dump Truck (A59230)
2019 Ram 4500 4x4...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2020 DRAGON ESP...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
