muddstopper
Veteran Member
I have ran across a 6068jd engine, only 150hrs on meter. engine I think came out of Katrina, but not certain. Anyways, the engine had the injector pump stolen and has set inside a open shed for several years. I tried to turn it over using a 4ft bar, but it didnt budge. Right now the engine is considered junk, but I thought I might give it a go trying to unstick it. Without tearing it down, any suggestions on how to go about it. The engine does not have any water in the oil pan and the water mark doesnt go up to the dip stick, So its a maybe at best. I dont mind spending a little time fooling with it to see if it will unstick, but I aint going to tear it down and spend the money to rebuild. I have access to a loaner injector pump to try and get it running, but at $1900 for a new pump. I dont want to spend any money until I know it will run.
