3-Point Hitch Stuck 3-point lowering knob
/ Stuck 3-point lowering knob #1
JohnnyD
Hello everyone. I recently purchased a used B-21. I attached a new Land Pride post hole digger this afternoon. When I tried to adjust the lowering speed of the implement, I found the lowering speed knob stuck. (I would assume in the fast position based on how quickly the PH digger dropped.) I have only tried turning it by hand. Is it a bad idea to use a vice grip or some other tool to persuade it a bit? The tractor is a 1998 and it is my understanding that the 3-point hitch was never used. Thank for the help in advance. John
/ Stuck 3-point lowering knob #2
Yes it is a bad idea to use a vice grip. Did you try adjusting the knob when the PHD was both lowered and raised? Did you take off the PHD and try again?
I would look and see if something can be loosened with a squirt of WD40 if these steps dont work. One minute with vice grips can result in days of work if your not careful (although I know how eager I am to use implements when I first get them too)
Best of luck with this and tell us how it goes.
Thanks for the advice. I tried with the implement up/lowered, PTO engaged/disengaged engine running/off. Dosn't move at all. Even so, I'll try to keep those tools in the tool box-at least for now.
/ Stuck 3-point lowering knob #4
I agree with Old Wanker for the most part. Pull the knob off. Should slide off with a little help from a prying device. Pull the plastic panel off, two wing nuts (if they're still there) at the top and it's just sorta latched in at the bottom. Spray where the shaft goes into the valve with some WD or equivelant and let it soak in good over night. Put the knob back on and work it back and forth. If it's still stuck, go ahead and try the vise grips to give you a little extra torque, just go easy and use some common sense and you should be able to free it up. Like you said it's probably never been used. Try the lube and some gentle persuasion and you should be able to free it up. Clamp the vise grips to the shaft and not the knob.
/ Stuck 3-point lowering knob #5
I have the same problem John... However, my tractor (L2850DT) is about 9 years older than yours! Let us know if you have any success...
Good Luck!
Thanks for the posts. I already have taken the knob off. Will try the WD-40 and very gentle persuation with a vice grip if nessesary. I will post tonight with the results. Thanks again. John
/ Stuck 3-point lowering knob #7
John, did you remove the access panel that Kubmech referred to? On my B21 I have see where you get a build up of dirt under there and it would also let you get lube right where the shaft goes into the housing.
MarkV
You guys are great! I wish I could buy all of you a beer! Four years of crud was no match for WD-40 and the vice grips. Thanks again. John
/ Stuck 3-point lowering knob #9
Good deal John............Hmmmmm, I wonder what a "virtual" Bud would taste like...Bottle of course.
Not too sure on what it would taste like. But definently bottles. That gives me an idea. Could you imagine the posts if we were to poll TBN readers on there favorite beer? Thanks again, John.
/ Stuck 3-point lowering knob #11
I assume you mean a glass bottle. I just can't get used to drinking a beer out of a wide mouth plastic bottle sold at events....yech!
Jeff
/ Stuck 3-point lowering knob #12
OK, how many bottled beers could you ice down in the bucket of a B21 FEL? This may be a research project I’ll have to study---------for the benefit of the forum---of course./w3tcompact/icons/eyes.gif
MarkV
/ Stuck 3-point lowering knob #13
<font color=blue>Clamp the vise grips to the shaft and not the knob.
</font color=blue>
Good point KubMech. Here I was with pictures of JohnnyD putting the vice grips on the knob.
/ Stuck 3-point lowering knob #14
I believe there are at least seven variables. Perhaps you can come up with some more. Im guessing these would be:
B - amount of beer
C - cooling factor (bottle or can)
I - amount of ice
N - number of people drinking
T - how hot the day is
S - sports factor - whether theres a game on or not
W - presence of the wife
Now I just have to think of an equation to put them all together.
/ Stuck 3-point lowering knob #15
B= ((NC)(2+S+I) to the power of T) * Square root of W; where W = -1 if wife around and 1 if not.
Because the square root of -1 is "i" meaning imaginary. And we all know that the consumption of beer is only imaginary if the wife is around. /w3tcompact/icons/smile.gif
Do I get a virtual beer too? If so, make mine a Bass.
Hey guys, I new there were a much more important things to discuss than my stuck (now un-stuck) 3 point shaft. I believe that the "positive beer factors" (B, C, I, T, N) are inversely proportional to W. Thus as any one of the positive beer factors increases, W becomes an ever increasingly smaller number. Eventually, if any one, or the combined product of the positive beer factors becomes to large, W will ultimately=0, thus the final number = 0. By the way, Bass gets my vote too ... John
/ Stuck 3-point lowering knob #19
P and W factors are dependant on one another. As W tends to zero so does P. (no wives around you can just pee in the bushes!)
Sooner or later this thread is bound to be moderated ...
832775 (A61166)
832775 (A61166)
New/Unused Quick Attach Double Hay Spear (A61166)
New/Unused Quick...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
iDrive TDS-2010H...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
