Stuck 1980 1050 John Deere Brake drums need to replace seals .
   / Stuck 1980 1050 John Deere Brake drums need to replace seals . #1
Cvilledeere
After heating and using a puller it won’t budge . What’s the answer. Thanks in advance
   / Stuck 1980 1050 John Deere Brake drums need to replace seals . #2
A few vids on YT for your Yanmar (JD) machine. I think Hoye Tractor has one just for this too.
Thank you so much
I found them a the local John Deere dealer . The 4 seals all the same , 2 to the side turned back to back at least that’s what I’ve read they really look large , but they went by the serial number. All 4 was about 24$
Did your drums come off easy? I’m still soaking the splines with P B Blaster , nothing’s budged yet .I found an after market brake kit with the 4 shoes and springs for almost 200.$
I tried something tonight .I took a bicycle inertube cut it stretched it over the hub of the brake drum put a hose clamp over that , poured P B Blaster Down the tube crimped the end and put some air pressure on top of the liquid hopefully forcing it in the splines better it ran out the Backside of the drum maybe it will finally give up.?????????????
   / Stuck 1980 1050 John Deere Brake drums need to replace seals . #7
When PB Blaster can't, pull out the big gun - - - Seafoam's DEEPCREEP
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2024 ATLAS CORPO PACF44 PORTABLE DEWATERING PUMP (A54757)
2024 ATLAS CORPO...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
Utility Trailer (A52377)
Utility Trailer...
