Stubborn quick connects.
/ Stubborn quick connects. #1
Mighty Dodge
Platinum Member
The Hereford Zone, MD
JD 4200
I sold my mower and all the attaching hardware. I'm unable to get the quick connects for the lift cylinder unhooked. See attached pic. The tractors been sitting for over a week, I moved the control valve both ways and re-centered it and finally loosened the hoses.....they still won't budge. They've probably never been disconnected since new so I sprayed them with Gibbs (penetrant) also.
Suggestions please.
John
/ Stubborn quick connects. #2
Some style have a notch you have to line up with a little pin.(skid steers use this) turn the collar to line them up.
Yours look similar.
/ Stubborn quick connects. #3
I use a wrench and a hammer
I clamped vice grips on them, tried wiggling all directions, tapped on the vice grips with a hammer...they're stuck.
/ Stubborn quick connects. #5
Unscrew the hose from the coupler. Relieve all pressure.
If still stuck, Take both hoses off stuck couplers.
Remove entire assembly and work with it in a vise.
Make sure to mark or remember which fitting is on top.
Finally got'em disconnected. Had to use my biggest drift and hammer. The male ends are fine but the female couplers are pretty trashed. The little detent balls that hold the connectors together are just about pure rust. Oh well next time I'm in Tractor Supply I'll get some new ones.
Crustbuster 6020 TW36X6 (A64119)
Crustbuster 6020...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2009 Ford F-550 Versalift Bucket Truck (A61573)
2009 Ford F-550...
AGROTEC ASE1054 TOWABLE SPRAYER (A64280)
AGROTEC ASE1054...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
(4) Cattle Gates (A64119)
(4) Cattle Gates...
