Strobe light bar
/ Strobe light bar #1
joe04785
Maine
XR3037
Hey everyone, looking to mount a strobe light bar to the roof and was looking for ideas on how everyone has done it to there tractor. Any ideas are much appreciated.
/ Strobe light bar #3
I use the existing brackets. It's not a 'bar' but a single strobe. You can have two, one on each side. The plug should be there, its not a regular 12v plug. Its called a 'Hella Plug" here is the link:
And here is the beacon I use:
What I did was drill a hole in a small length of plate steel, I think 2in wide. I then welded round stock to the other side of the plate steel from the hole. I bent that round bar 90 degrees and attached it to the beacon. Wired it up and and done.
I show my becon at the 10:13 mark of this video:
/ Strobe light bar #6
Fabbed up this mount from old mirror brackets. I already had these inexpensive strobes and the little momentary switch that changes the 32 strobe patterns. All I had to buy was the Hella Plug mentioned earlier.
/ Strobe light bar #7
Nice! They should provide a good safety strobe for sure
/ Strobe light bar #8
I've used a halfway long (wide if you will) bar on top of the cab for years now. The magnets are plenty strong to keep it in place on the roll bar even with the plastic roof in between.
/ Strobe light bar #9
Something else to think about...I see that Amazon has led strobing tail light bulbs. Might save someone the hassle of fabbing something up.
/ Strobe light bar #10
$35.99 on Amazon, should be magnetic base, plugs into 12v oitlet, and not sure about this specific model, but has a rocker switch to turn it one, common on construction vehicles, mail cars, ect. I believe yellow/amber is 50 state legal; I think white is not allowed in Texas; I'm pretty sure green/white is allowed some states, but not all.
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
CONEX BOX (A65643)
CONEX BOX (A65643)
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
70in. Skid Steer Root Rake (A65640)
70in. Skid Steer...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
2019 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
