Stripped transmission oil plug
   / Stripped transmission oil plug #1
nhman
Virginia
Kubota B2910
Well, I went and did it. I stripped the threads on the transmission housing putting the plug back in for
hydralic oil doing the 50 hours service this weekend. My neighbor is a mechanic and had a tap and die set and put in a new plug, but it still has a slow leak.
At this point, what are my options if any. If the only option is to have the dealer replace the transmission case, what kind of money would I be looking at?
After all this time changing oil.....%$#
   / Stripped transmission oil plug #2
In a case like this, I'd drill and tap for a larger sized plug. I'm sure you've a metric thread in there. I'd find the next larger sized equivalent pipe thread and go for that.
It's going to be a messy job, but I'm sure the transmission case price will be very salty.
   / Stripped transmission oil plug #3
Is it the gasket thats leaking? Plumbers thread seal might help.
Egon
   / Stripped transmission oil plug #4
Nylon washer will fix you right up.
Thanks....can I get the washer at Tractor Supply? I am not real mechanical and have not heard of such an animal
   / Stripped transmission oil plug #6
</font><font color="blue" class="small">( Thanks....can I get the washer at Tractor Supply? I am not real mechanical and have not heard of such an animal )</font>
Try any auto parts store.
   / Stripped transmission oil plug #7
I don't ever remember seeing one at TSC, but if you have a ACE / Truevalue Hardware, they carry them. Like has already been said, a auto parts store might, if it is a standard plug size for cars.
   / Stripped transmission oil plug #8
NAPA or any of the larger auto parts stores carry "oil plug strip kits"... or stop at most "quick lube" stations, they should have an assortment of replacement plugs/sizes...
   / Stripped transmission oil plug #9
Also remember to only tighten enough so it does not leak,easy to muscle it down and keep truning til the threads are gone. Good luck
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2014 Ford F150 XL Pickup Truck (A53117)
2014 Ford F150 XL...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53473)
Michelin CARGOXBIB...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
