STRIPPED DRAIN PLUG ON MY 3054
   / STRIPPED DRAIN PLUG ON MY 3054 #11
I know what I would do if it were my machine.
I would pull the pan and either replace it (depending on cost) or at least get the original pan repaired by someone who knows what they are doing with this type repair.
I wouldn't be taking any chances with my engine over damaged oil plug threads.
   / STRIPPED DRAIN PLUG ON MY 3054 #12
</font><font color="blue" class="small">( Well, dumb minds must think alike cause I was thinking the same thing. At least remove it to do a good job of repair. But, then I started thinking that my pan doesn't leak now and don't want to cause another problem by disturbing that seal etc. I dunno... still pondering. )</font>
And, if you go this route.. for that matter whichever route you go.. find the correct torque specifications for that bolt. It would ruin your whole day to install a new pan and then strip the bolt again! /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
Bob
   / STRIPPED DRAIN PLUG ON MY 3054 #13
To jimlk3045 Years ago I raced a Alfa Romeo with an aluminum engine and used heli-coils all the time. If you install them with a little lock-tite they work just fine.
   / STRIPPED DRAIN PLUG ON MY 3054 #14
Yes, I agree, I also did the heli-coil w/loctite on my 3054. No problems here.
I ended up getting a "piggyback" repair plug from NAPA. Seems to be working so far.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2020 John Deere 5065E 4 x 4 Tractor, S/N 1P45065EPLK406145, John Deere Diesel Engine, Cab, 3 Point (A59076)
2020 John Deere...
PALADIN INDUSTRIAL SCREENER (A58214)
PALADIN INDUSTRIAL...
Fast 9613N 1300 Gallon Sprayer (A57148)
Fast 9613N 1300...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
