STRIPPED DRAIN PLUG ON MY 3054
   / STRIPPED DRAIN PLUG ON MY 3054 #1
jimlk3045
Went to do my first oil change and noticed one plug was loose because the hole is stripped. Any ideas on how to repair?
Thanks,
Jim
   / STRIPPED DRAIN PLUG ON MY 3054 #2
Check with your local auto parts dealer. He'll probably have some self tapping, oversize plugs.
   / STRIPPED DRAIN PLUG ON MY 3054 #3
I remember when I was a kid we stripped a spark plug hole on an old Evinrude outboard motor. My dad got something called a "heli-coil" (not sure of spelling..) and that solved the problem in this case.
Bob
I've used helicoils before, just wanted to know if there was an "approved" method of repair that's been done by any forum members.
Thanks,
Jim
   / STRIPPED DRAIN PLUG ON MY 3054 #5
I know when I changed my oil for the first time both of my drainplugs were just barely snug. They have that rubber gasket setup that's a little different. They didn't tighten up like automotive style drainplugs.
   / STRIPPED DRAIN PLUG ON MY 3054 #6
If this is a brand new tractor purchased from a dealer, I would think it could be covered unver warrenty. I do not believe that a helicoil is the fix for this application. The stripped out drain plug repair kit is your next best option, but they reduce the flow considerbly. I would pull the pan, and get it fixed properly. Even if that ment welding in a new fine thread nut to the pan. If the helicoil fix leaks, or cuts loose under operation, and you dump your oil, it could be a costly mistake. Don't mean to put fear into you, but when you go operational, I would leave nothing like that to chance.
It's a used tractor. I've found some kits made for repairing stripped drain plug holes. Does anyone know the size of this hole?
   / STRIPPED DRAIN PLUG ON MY 3054 #8
</font><font color="blue" class="small">( It's an used tractor. I've found some kits made for repairing stripped drain plug holes. Does anyone know the size of this hole?
)</font>
No, sorry.. but I'm just curious.. how much does a whole new pan cost? How big a hassle to install it? Might be easier in the long run than messing around with this stripped bolt-hole problem? And in the process you could replace the gasket, clean out any crud, see the condition of the connecting rod bushings, etc...?
Probably a dumb thought..?
Bob
Well, dumb minds must think alike cause I was thinking the same thing. At least remove it to do a good job of repair. But, then I started thinking that my pan doesn't leak now and don't want to cause another problem by disturbing that seal etc. I dunno... still pondering.
   / STRIPPED DRAIN PLUG ON MY 3054 #10
</font><font color="blue" class="small">( Well, dumb minds must think alike cause I was thinking the same thing. At least remove it to do a good job of repair. But, then I started thinking that my pan doesn't leak now and don't want to cause another problem by disturbing that seal etc. I dunno... still pondering. )</font>
I kinda go with Trev on this one. It may be much less hassle and a better fix all around to just buy a new pan. Generally speaking, Kioti parts tend to be much less expensive than many other brands, so you may be able to get one cheap enough to make it worthwhile.
You could get into filling and retapping and all of that, but a new one would be best.
Let us know how it turns out.
Happy New Year!
John
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
5th Wheel Dolly (A49461)
5th Wheel Dolly...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
