String Trimmers
   / String Trimmers #1
Big Al
So I got permission to get a nice string trimmer today, and I didn't even ask!
I don't have a big yard (just under 1/3 acre), but the trimmer will back up my riding mower since I skipped getting a push mower.
Any thoughts or advice on good string trimmers? If cost were no object, I'd get a top of the line Stihl. However, cost is an object and I really won't be abusing it like a Stihl likes.
I'm thinking $150 is about as much as I can spend. Lowe's had Troy-Bilt trimmers with interchangeable heads that seemed pretty nice. Especially since I can get an edger, blower, & cultivator attachments for about $50 each. Seems like a good way to get several tools for less money than buying them all separately. Of course, my experience is a tool that does a little of everything never satisfies at anything. Would that be the case here or, since I'm a light duty user, would something like that fit the bill for me?
   / String Trimmers #2
Don't just assume a Stihl is out of your price range.
I believe the FS-45 is well within your price range, and will still be going strong when that MTD you looked at is in the dumpster.
Been There Done That.
   / String Trimmers #3
A Stihl FS45 is in your price range @ $170 as is an Echo GT201 @ $150. Of course, prices could vary a bit--this is just what I found with a quick internet search. I'll second the opinion that down the road you'll be much better off making the initial investment in a top-notch (Stihl, Echo, Husqvarna, Shindaiwa, etc) trimmer than you will in a lower grade machine like the Troy-Bilt. Plus, if buying from a dealer has it's benefits if there is a problem or whenever you need service. Just because you buy from a dealer doesn't necessarily mean you'll pay more initially or for parts/accessories--the dealer I bought my Shindaiwa from actually sells Shindaiwa 2-stroke mix $.50/bottle cheaper than Lowes or HD, and the price I paid for the trimmer matched the best deal I could find online. Also, when it comes to attachments for that Troy-Bilt, some will work well, and some won't. For example, I'm sure the edger or hedge trimmer would work great, but the blower attachment will not have the power (mph & cfm) of a dedicated handheld blower.
   / String Trimmers
Actually, I expected and hoped to get advice on non-big box options. It's why I posted here. It seems as though plenty of "hard-use" consumers frequent this board, so I figured there would be a good body of experience on trimmers since they seem to go hand-in-hand with garden tractors.
I guess I was mostly wondering if that Troy-Bilt was too good to be true. Is Troy-Bilt just rebadged MTD any more? I'm guessing it probably is. It looks like Stihl makes a similar unit, although it's about twice the price.
I like Stihl, so I might just have to drop by the dealer and poke around.
   / String Trimmers #5
I got a troy built trimmer. It's heavy. It's also dead after three seasons. It had enough power, but I can't get it to start. I need to spend some time on it to find out why, but I'm seriously considering something lighter and dumping it.
Eddie
   / String Trimmers #6
5 years on my Stihl and I trim more than my fair share...service also a key to consider.
   / String Trimmers #7
I swear by McCulloch. I had a $70 unit. Used it for 8 years. Gave it to a friend. He still uses it; now going on 14 years. I bought a larger one that is now 6 years old. Always easy start even with old gas. Never any problems. I also have a Mac610 chain saw, now 23 years and still ticking.
   / String Trimmers #8
I paid about $240 for my FS55RC two years ago. I put a new spark plug in it and checked the air filter last month is the first time anything's been done to it other than adding the gasoline/oil mixture. My next door neighbor's 4 year old $80 Craftman bit the dust. He said it would run, but he broke the starter rope and Sears said it would cost more to fix it than a new one cost. So, instead, he bought a Stihl FS45.
I'm sure there are different opinions, but having a considerable amount of experience with string trimmers; 3 brands of electric, 4 brands of gas, both straight and curved shafts, I can't imagine ever buying one again without the straight shaft. To me they're so much easier and more efficient that they're worth the cost difference. And I guess I'm not alone in that opinion since I've never seen a commercial operator use a curved shaft.;)
   / String Trimmers #9
Another vote for the Stihl. I've got a trimmer that's still going strong after 8+ years.
As was mentioned, being able to get the Stihl serviced is a big consideration.
hud
   / String Trimmers #10
It is for me, even if I never need it. And that's why I bought mine and my Toro mower from a local dealer rather than one of the big box stores. I have nothing against the big box stores and, in fact, spend a lot of money with them, but not on anything I figure I might someday want repaired.
Bale Spear - Fits John Deere 300/400/500 Series Carrier (A55218)
Bale Spear - Fits...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55301)
GOODYEAR SET OF...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
JOHN DEERE 850K WLT CRAWLER DOZER (A52705)
JOHN DEERE 850K...
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
