String Trimmers
/ String Trimmers #51
I like the idea of a battery powered trimmer, but if you have heavy work to do, you can't beat a Stihl FS 90 with handlebars. I have two of them. They work great as a string trimmer and equally well with a brush cutter attachment. Veeeerrrrry easy starting, always.
MF
/ String Trimmers #52
I have a 3 year old Husqvarna 128 string trimmer that doesn't run anymore, but really doesn't have that many hours on. I replaced the primer bulb and carb a year ago, used it a few times and won't run more the minute or two now. Thinking about going with a cordless trimmer, like Kobalt 40v or Atlas 40V, or having the Husqvarna serviced. The Husq would obviously be more powerful, but the battery ones are real convenient, and kids/wife can easily start and use. Ive got two acres, about 0.75 of Yard yard, about 0.75 rough yard, some fence line, around the house ect. Anyone have thoughts on durability of the cordless or cost of deal service of Husq? My current cordless tools are Rigid, but they don't offer a weedeater. Ryobi 40V
Kobold 40V
Atlas 40V
Husqvarna 128 dealer service
other thoughts?
Like most of these threads, guys recommend what works for them and not what will work for you.
Figure out how long it takes for you to trim your yard/lot. I am betting a decent battery powered trimmer is gong to work out for the best.
That assumes you are not having to cut saplings or huge weeds.
I have 20 acres but only 2 acres that need tending to. I plan on getting a battery trimmer. There are areas I can use Round Up to avoid having to trim but even if I do not do that, I can trim my yard in less than 30 minutes and I trim every 2nd or 3rd week.
I just got a ZT so my trimming will be reduced somewhat.
/ String Trimmers #53
I just placed a DeWalt 60v weed wacker into service yesterday. I am running it with DeWalt 9.0AH batteries. 15 minutes of run time on high is all we got. A little disappointed in that. It runs so nice and quiet. Shreds grass really well. Lighter than Stihl FS90.
Bought mine several years ago and use it a lot, have high tough grass and weeds at the pond runoff and easily go past 30 minutes with 1 battery but I have never used the high power and also don’t use full speed because the weeds will get stuck above the head.
Liked this so much that I also bought the tree trimmer, chainsaw and mower no more gas and not starting, making chores a lot more pleasant.
/ String Trimmers #54
Yeah I’m a little confused as to why the DeWalt 9AH batteries fade fast, too. I thought they’d run 1/2 hour
/ String Trimmers #55
I wonder if my less than stellar battery time was het related?
Do batteries have shorter life in direct sun @ 95*? They are 9AH.
I see DeWalt makes a larger 12AH battery, but they are $245!
Thats $100 more than I paid for the 60v weed wacker brand new!
I keep my battery’s (3) in a small cooler bag when it’s hot and keep them in the shadow, they really don’t like the heat.
/ String Trimmers #56
Bought a 58 volt ECHO weed whacker to match my chain-saw;haven't used my Stihl gas versions since.
/ String Trimmers #57
We have always used shindaiwa trimmers. They were all gas. I was always trading in or repairing about every two years. One time it was a bad carb. I think most problems started several years ago when adjustable jets were stopped and fixed ports became the standard (remember when we used to adjust the carb?) Anyway, we went to EGO 56 v with the carbon shaft (a little lighter). We now have 2 trimmers, 2 blowers, a chain saw and a lawn mower for grass areas. We have about 4 acres, so the trimmers are used in the weed and rocky areas - and there are a lot. I do think whatever brand you decide on, best look at the entire line of products. That is the key to keeping batteries. For example, you can get a leaf blower with charger, battery and tool for $199. Or you can get the battery for $149. We have used Ego for about 4 years. The tools and batteries have been very good and no bad anything so far. Choose wisely because you may want all the batteries interchangable. I did. Ego says all their batteries will fit any Ego tool. First looked at DeWalt because of all my 20 and 60 volt tools. But my neighbor had one, and it would not last very long compared to Ego (battery usage wise). But is you want to cut sapplings and vine type brush, you may have to stick with gas with a blade option. I did a lot of cutting small trees with the shindaiwa trimmers (which I still have and use sometimes on heavy brush). Best Wishes. Larry
/ String Trimmers #58
I think that most of the battery packs (larger ones - probably not DeWalt) use the 18650 tac light batteries wired in an arrangement of series to correct voltage and parallel to get the most amperage they can. I am wondering if since all motors run via rated wattage, and voltage x amperage = wattage, then a battery pack with low voltage output must produce a higher amperage output to the constant required wattage to operate the motor. Well, that is free, so you know what it is worth.
/ String Trimmers
Picked up a Ryobi 40V for $139.99 with charger and 4.0AH battery. Im sure one charge won't do everything, but a recharge or two should do it.
/ String Trimmers #60
I have the Husky 128LD too. I bought it used about 10 years ago. I always run it dry before storing it and it always starts right up--until this spring when it would only run a short time, then die. The fuel filter line was broken off. The ****ty Kalifornia gas finally ruined the fuel line. Bought a kit for around $15 on Amazon. Already had the "special" carb adjustment tools. Youtube is a great source of info on tuning the carb. If you don't work on machines yourself, you may want to have a shop take a look at it. These are very good machines and unless you have the same branded batteries for other tools, I don't care for the battery powered yard tools. Just my opinion. Good luck
2015 Chevrolet Suburban 4x4 SUV (A59231)
2015 Chevrolet...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
