String Trimmers
   / String Trimmers #1
Mark_in_NH
Veteran Member
Moultonborough, New Hampshire
New Holland TC35D w/ 16LA FEL
Has anybody replaced the head of their string trimmer with any of the aftermarket heads that you see advertised ?
On TV you see the adds for "Weed Trasher", I saw an add the other nite for one called "Load -n- Cut"
The factory head on my Ryobi has bit the big one and I am looking for something to replace it with, besides another standard type string head.
Any ideas or suggestions ?
   / String Trimmers #2
I swapped out the head of a Ryobi I had a couple of trimmers ago. It was the head with the three plastic knives. It worked really well on open grass, but the blades wore-out quickly if you bumped them against concrete as I usually did. (Trimming against the foundation) The good part was that the blades were replaceable. I would recommend them only if you cut only grass/weeds and don't have many obstacles to bump.
   / String Trimmers
Dave,
I just returned oneof those to my local hardware store, still in it's original package. I just knew that I'd constantly be replacing the plastic knives.
1067 (A53342)
1067 (A53342)
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
