String trimmer runs well but does not idle.
   / String trimmer runs well but does not idle. #1
msjanket
My Echo 311 runs good but will not idle. It has the adjustment to control idle, but does not seem to make a difference. I have a new carburetor. Any suggestions?
   / String trimmer runs well but does not idle. #2
I'd change the spark plug for good measure and the fuel pump. Its most likely the pump.
   / String trimmer runs well but does not idle. #3
So if you turn the idle screw as high as it will go it doesn't make a difference?
   / String trimmer runs well but does not idle. #4
New carb you will probably have to set the idle jet and high speed jet.
   / String trimmer runs well but does not idle. #5
Is there screen attach to muffler built up w/carbon exhaust?
I was just surfing on the Net and came across a You Tube that showed where the Echo hidden jets are and how to adjust the jets. You need the small D shaped tool and you need to make sure there is no plastic plug in the hole that precludes engaging the small D onto the adjusting screw. It's all so simple......when you have somebody tell you what to do!!
Thanks to all for the participation.
   / String trimmer runs well but does not idle. #7
Yep, and you probably can't buy the D shaped tool in the U.S.
I ran into this before: The manual will say "Take to qualified service technician" because the EPA doesn't want you adjusting the carb and that 1.5 gallons of gas you burn a year may pollute the air with 10% more emissions.
So the net effect is instead of paying a $115 service bill on a $80 trimmer you throw the trimmer in a landfill and buy a new one because the EPA didn't want the 10% additional pollution on 1.5 gallons of gas!! Thanks EPA, that's really saving the environment!!
Or take your chances (like I did) and buy the D shaped tools from what is hopefully a legitimate Chinese business (via ebay) and wait 10 weeks for delivery.
...then feel the rush of getting a package in your mailbox mailed straight from China containing illegal contraband!
   / String trimmer runs well but does not idle. #8
Note: Some people are able to make the D shape connectors out of electrical butt splices / crimp splices.
First, it is a new carburetor. I took off the externals of the muffler and the screen was clean as a whistle. Could not find a problem whatsoever.
I bought a carburetor on ebay for the 311 Echo, just became available recently. It does NOT have the main jet adjustment screw, it only has a rather strange adjuster that affects the high end. When I open it full, the accelerator controls start to get wheezy and run what appears too rich. It does not have a specific high end jet adjuster. I found this out after ordering a small D adjuster tool! There must have been a change in availability status of the adjuster as I got one right off Amazon. Go figure.
My old carburetor, probably OEM, does have the high speed adjuster.
So, I'm trying to get it all figured out before the snow flies.
   / String trimmer runs well but does not idle. #10
I am use to seeing three screws, L H and idle, I have never seen one without and idle screw.. I wasn't referring to the "H" screw..
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
JMR tree boom attachment (A53421)
JMR tree boom...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
