strengthening tie rods
/ strengthening tie rods #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
One of the weak links on a tractor especially if you go in the woods with it. On my old tractor, I was able to unscrew the tie rod ends, slam a pipe on it, weld the pipe to the tie rod and screw the tie rod ends back in. On the new tractor the tie rod ends are welded to the tie rod so I cannot use that technique I used on the old one.The tie rod only has a quarter inch of clearance at the center part of the tractor. Before I go the extra work of finding the same size tie rod end, cutting a tie rod out of pipe, tapping threads into the pipe so as to be able to screw the rod ends into and finally slamming another pipe onto this to gain double wall strength has anyone come up with a technique of strengthening their tie rod of the one piece variety?
/ strengthening tie rods #2
Arrow, do you have your tractor yet? I just looked at my 3215, and I don't see how you would be able to do much of anything. You have the ram that goes side-side and the ends that flex-pivot that connect the ram to the hub. There really isn't any open tie rod material to beef up. I guess that you could make some sort of guard for in front of the steering, I just don't see how to beef up the actual steering though. :confused:
/ strengthening tie rods #3
Watch were you are going and you will be fine :thumbsup:
There is no ram ( I'm assuming this is your power steering?) on the 3016 that acts as the drag link or tie rod. It is a straight piece with welded ends.
I've watched where I'm going and have been less than fine. The woods here are of a cantankerous nature and all the tie rods I've bent I've done backing up.
As soon as I get this tractor, I'm gonna take off the tie rod and weld two pieces of 1" angle iron around it
/ strengthening tie rods #7
Folks, there is a reason that the tie rod is designed to be weak link in the front end. Think about it, as soon as you strengthen the tie rod, what do you suppose will be the next weakest link to bend or break???? Probably something that will cost more to repair than a tie rod.
Its such a weak link that it costs $270 per to replace which is a ridiculous amount for a 3' 5/8" rod with tie rod ends welded to it.. Lets look at this from how I've bent tie rods. Going forward, the front axle has negotiated a "stick up" which in my case has been a 1" to 1 and 1/2 " of bush or sapling stubble. Backing up however and watching where you are going backwards, this little stubble is enough to render a bend in the tie rod when it gets hung up. By strengthening this area, the stubble gives way instead of the tie rod. I had bent my previous tie rod 3 times in 5 years before I strengthened it. In the next 23 years I have had no problem in any fashion. I'll ask you what is the next thing to bend or break in a case such as this? For me, there has been nothing else to do so except the stubble.
/ strengthening tie rods #9
My dad bent the tie rod on his old 47 International truck. He pounded it straight and welded an angle iron to it. It only lasted until the engine seized up some 35 years later.
Sent from my iPad using TractorByNet
/ strengthening tie rods #10
Some manufacturers still have the drag links below the axle on the tractors they are producing. Most new designs have them above so this does not normally happen.
/ strengthening tie rods #11
I straightened my rod several times after I bent it the first time. Easier to bend each time. I took it to a shop and had them cut the end off and weld it to a new rod so it's now like new. they threaded the other end so it would screw into the adjuster. It cost me forty dollars.
Very true art . I'm referring to the ones that are situated in back of the front axle.
/ strengthening tie rods #13
I had the same problem with my 76 International Scout. Solved it the same way...... Engine still turns over though.....body is gone.
/ strengthening tie rods #14
Hehe we used to joke that that old K5 had 2 different rotations of the pistons. They would go around with the crankshaft of course. But these were so worn out that the pistons would rotate which cylinder they came back down into. :laughing:
/ strengthening tie rods #15
I too bent the tie rod on my JD 790 running into a small stump. My good friend who is a master mechanic just happened to come by the next day. I was commenting on just how vunerable the location of the tie rod was and I thought it could be beefed up to resist future damage. He urged me not to do it. As stated above if you made the tie rod damage proof something else has to give. Maybe something more expensive. Would some kind of skid plate like off roaders use work? I think those big skidders loggers use also have skid plates on their undersides.
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
2013 Kia Soul SUV (A66738)
2013 Kia Soul SUV...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2014 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2014 (INOPERABLE)...
2012 ATLAS COPCO  AIR COMPRESSOR XAS 375 (INOPERABLE) (A68842)
2012 ATLAS COPCO...
Unused 2023 Unused Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
Unused 2023 Unused...
