If you are into pulling/lifting heavy objects with a FEL bucket you may want to consider strengthening your bucket. The primary purpose for the retrofitting of my bucket was to accomoodate a set of pallet forks. My bucket had been strenthened at the installed hook locations inside bucket (see gussets inside bucket) when the tractor was initially delivered. Later I asked Michigan iron & Equipment to also fit my FEL bucket for forks. The dual advantage is the way it strengthened my bucket because buckets can be distorted sometimes under heavy use.
Here are some pictures of the nice job of accomodating the above needs that was accomplished by the crafty engineering folks at Michigan Iron & Equipment.
rimshot
rimshot
