Streering wheel and shaft comes loose
   / Streering wheel and shaft comes loose #1
dlat
ferguson TO-35
Tc40 streering wheel comes loose if I pick up on it. Normally not an issue but is more of an issue of driving uphill. Any input is appreciated
   / Streering wheel and shaft comes loose #2
Do you have the telescoping steering wheel?
   / Streering wheel and shaft comes loose #3
And, regardless if you do or don't, does it come off, or just move up and down?
   / Streering wheel and shaft comes loose #4
If you have the telescoping wheel, NH is known for the lock knob in center of steering wheel becoming rusted and inoperable. Mine is rusted tight. Possible rusted loose?
Not a telescoping shaft or adjustable shaft. It pulls out but goes back in with little issues just need to turn a little to find the notch
   / Streering wheel and shaft comes loose #6
Take the plug (#4) off and tighten the nut (#7).
New Holland TC40 - 4 CYL COMPACT TRACTOR(01/98 - 12/05) Parts Diagrams
   / Streering wheel and shaft comes loose #7
I doubt it's the wheel coming loose on the shaft. More likely the shaft is slipping up the column and coming free of the steering valve below. There's no breakdown on the steering column so bushings, washers, snap rings, ETC apparently aren't available separately. It's either a complete column or fix what you have.
   / Streering wheel and shaft comes loose #8
While your in there drill a drain hole in the steering tube. Mine was filled with rusty water and crud. The steering valve seal is leaking but after cleaning the tube and seal on the valve the leak is at an accepted level of leak.
MANITOWOC QD08902A ICE MAKER (A51248)
MANITOWOC QD08902A...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
1275 (A50490)
1275 (A50490)
