Strap Lifter Attachment
   / Strap Lifter Attachment #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I have a 30 gallon gas container that I find difficult to move. I figure it weights over 200 pounds. I considered welding a quick attach plate to it, but I was reluctant to weld to a gasoline container and did not want to use up my last quick attach plate for a single use purpose. I figured if I could attach a strap with a ratchet to a quick attach plate, it would be easy to move.
I bought two steel cable clamps and welded the u-bolts to the quick attach plate. I cut the bolts short with about a 45 degree angle on the cut, so I would have a lot of welding area. I had to grind a little metal out of the center of the u-bolts to have room to put the cable hook in. I put a board over the end of the quick attack plate to allow the tank to clear the hooks. I hope this is strong enough. I picked up the tank and it worked fine, but it was only half full.
Bob Ripley
Another picture
Bob Rip
Last picture, unless there are additional request.
Bob Rip
   / Strap Lifter Attachment #4
Very nice job. Did you get any pictures of the lifting?
PJ
   / Strap Lifter Attachment #5
A picture lifting the 30 gallon gas container would help me to understand how it worked. /forums/images/graemlins/confused.gif
I knew that was coming. I need to mount a camera on the PT. I will try to take one tomorrow. It's kida dark right now.
Bob Rip
OK I got the pictures. It was really easy to attach this time, although I need to add a couple of pieces of wood so the wood cannot fall off and then paint it.
I hope these pictures make it clearer. That 100K limit really makes me crop the picture.
Bob Rip
Another picture with the 30 gallon tank.
Bob Ripb
Last picture with this tank.
I have a few comments on the tank. It's got it's own pump which can load and unload the tank. It also fills through the cap. What I don't like about it is it's too heavy to move when loaded unless its on a smooth pavement. I think it was designed for use in a garage to unload gas tanks that have to be dropped. It does not really seem to be designed to be left outside. I generally keep a plastic bag over the top to keep moisture out. It also cannot be hauled in a vehicle when loaded since it has a vent which will let gasoline splash out. I buy gas in 5 gallon cans and it from them. Not the most convenient method. I got if from Northern.
Bob Rip
   / Strap Lifter Attachment #10
You know this gives me an Idea. I may have to weld a quick plate on the back of my two wheeled hand truck. Tilt it back a bit, float and roll or just pick it up and set it to a higher place. I guess I will need to add the loops to the hand truck as well.
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
UNUSED MOWER KING SSAB72-72" HYD ANGLE BROOM (A51248)
UNUSED MOWER KING...
NEWTON CROUCH 1-04-7612 FERTLIZER SPREADER (A51247)
NEWTON CROUCH...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
Informational Lot - Financing (A53473)
Informational Lot...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A51247)
UNUSED CFG...
