Strange things found in the forest
   / Strange things found in the forest #391
What is that in the picture? Looks like a run in with a Brown Recluse
Lighting strike exit hole (entry hole is probably more correct).
   / Strange things found in the forest #392
What do you suppose the structure is in the center of this old foundation? IMG_20161030_120859265.jpg
   / Strange things found in the forest #394
   / Strange things found in the forest #395
Somehow I don't think it is for a fireplace. For one, I doubt a fireplace that old would be in the center of the room; more than likely it would be built into the wall. Secondly, I'm not sure the structure is even a dwelling. The dimensions are not what I would expect in a livable room. Lastly, although I wouldn't expect an intact chimney to survive a couple of centuries, I see no indication that a chimney ever existed.
What do they do in NH? Could it be the remains of an old syrup or sorghum mill?
   / Strange things found in the forest #397
What do you suppose the structure is in the center of this old foundation?View attachment 487927
Not knowing the geographic location, although the trees suggest NE United States/Upper Canada through to NB, the central structure had to have been built to contain/protect something.
A WAG would be a semi-underground cool-storage building. The central structure would hold blocks of ice, covered in sawdust.
   / Strange things found in the forest #398
Sebago, Maine is my assumption. Remember, this is a cellar hole. The sill stones and timber sills are long gone and the floor has filled in some with leaves etc. The top of that center structure would have been the floor of the building. Very cool that it's still standing.
Center chimney is pretty common up here although you are right about it being a seemingly small building.
Edit: It is also neat to think that when that was built/dug, none of thoes trees arround it would've been there!
   / Strange things found in the forest #399
   / Strange things found in the forest #400
That is really neat. Did you take the picture? I also think I was a unique "foundation" for a center chimney fireplace.
Yep I took the picture... In Sebago. My initial thought was support structure for fireplace/chimney, however there are no signs of any chimney left. Also - that would be an awful rugged support for a chimney.
I plan on asking the historicak society. There is also an uncovered dug well lined with stone 50' away. Not sure how deep the well is because it is filled with leaves.
It is amazing to look at the timber around and wonder what it looked like back in the 1800s.
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A55301)
2023 NEW HOLLAND...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A55788)
2023 GMC Sierra...
John Deere 5603 (A53314)
John Deere 5603...
PIONEER PUMP 4 TRANSFER PUMP (A55745)
PIONEER PUMP 4...
