SSweet9c1
This past spring I purchased a used 2007 M9540 HD12 with just over 2000 hours. with 1353 loader.
After plowing with it the other day, every time I idled it down it made this awful groaning noise, it sounded similar to when you bottom out a hydraulic cylinder and deadhead the pump... I couldn't really tell if it was related to clutch position (hydraulic wet disc). As soon as I throttled it up the noise went away. As the tractor cooled down I could idle it down lower and lower before the noise came back.. IE. shortly after plowing I could only slow the engine to 1500 RPM and after 10 minutes or so I could get closer to 1000 RPM before the noise came back...
I have changed the hydro filters but not fluid. and the engine oil and filter.
The sound is definitely coming from in front of the driver's seat, and it seems like it is coming from near the steering column (top of engine area)
I was thinking it might be either turbo related (due to area of engine) or hydraulic pump related (due to pitch of noise)
Any idea where to start trouble shooting??? It runs great, and everything works as it should...
Jonathan
Jonathan
