Mowing Strange mowing issue
   / Strange mowing issue #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
I've seen a strange scenario from he 60" deck on my 5252.
I'm mowing dry grass but for some reason, the left rear wheel on the deck loads up with grass and then flips off a 12" x 2" patch every 100 feet or so. nothing accumulates on the other three wheels, weird. I'm thinking of swapping wheels around? Any thoughts?
Thanks,
Curt
   / Strange mowing issue #2
OhioGuy,
I notice the same thing on my 520xi Wheel Horse's 60" deck wheel when the grass is still somewhat wet. I've never noticed this to happen with dry grass cutting conditions. Where do you live in N E Ohio. I live in Conneaut. in Ashtabula county.
arthurb
   / Strange mowing issue #3
Has it always done this or just recently? Sound like the deck might not be discharging correctly.
   / Strange mowing issue #4
I'm wondering if one of the under-deck skirts or baffles is out of place causing stuff to blow out onto the wheel? Is everything as level as possible? Even tire press, gauge wheels set level? Maybe you need a mini kick-bailer to toss those patches into a wagon /forums/images/graemlins/tongue.gif /forums/images/graemlins/smile.gif!
G/luck
Joel
This is a new tractor, I've mowed about 5 times with it. I didn't notice this symptom until two mowings ago. I don't think the baffles are creating the problem, when I look at that wheel, it just seemed to accumulate grass and the other 3 wheels don't.
I painfully remember last years wet spring when you had to mow wet grass just trying to keep up. There were these big flaps of grass flying off all four wheels, it was such a painful mowing experience.
But in dry grass, on one wheel?
I'm just south of Akron, in Clinton.
Curt
   / Strange mowing issue #6
Curt, it's gotta be that's just where the wettest of the mowed clippings winds up. Is their any way to get those wheels off the ground slightly?
G/luck
Joel
Hey Joel,
That makes the most sense, that it's just wetter there! This deck is ground following so about all I could do would be swap wheels thinking its something to do with the tire composition or maybe email Cub Cadet.
I'll bet it clears up a little later in the summer when things really dry out or maybe I'm mowing just late enough in the evening that a little dew is present.
Why, ask why, as the Bud commercial goes!
If this is my biggest problem in life, I'm in pretty good shape.
Thanks,
Curt
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
Root Grapple (A50322)
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
1816 (A50323)
1816 (A50323)
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
