strange harmonics/vibrations
   / strange harmonics/vibrations #1
washita
south western michigan
pt 425, JI Case, Gravely Comm.10A
well.... at 330 hours now I am pursuing an unusual vibration when accelerating motor to full throttle, never encountered this before. motor mounts are tight (first thing I checked) lovejoy couplers?
   / strange harmonics/vibrations #2
Does it only happen when the PTO is engaged and a mower deck is installed?
no attachments are on the PT except for the pallet forks and the vibration occurs while parked
   / strange harmonics/vibrations #4
So, if you were to relieve the pressure on the PTO Pump, put a coupler across it, does it change the vibration? I guess I am getting at is how you get to wether it is like on a car... if you feel the issue under acceleration it is engine or tranny, and if you feel it under coast it is the wheels. Wondering if you can free-wheel your pumps, and see if the vibration continues. I would assume, probably incorrectly, that a pump with no load would have less chance of vibration than one under load.
my neighbor feels that the vibration is a transition problem between low idle circuit jets to high flow jets in the carburetor, if I have time this weekend the pumps will be disconnected from the motor and motor ran to check for harsh vibrations through rpm range, if problem surfaces it will warrant a carb. rebuild
2023 JOHN DEERE 3033R LOT NUMBER 90 (A53084)
2023 JOHN DEERE...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
BUYERS PREMIUM & PAYMENT TERMS (A52576)
BUYERS PREMIUM &...
2016 FREIGHTLINER CASCADIA DAY CAB (A52576)
2016 FREIGHTLINER...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
