Strange fan and alternator problem on our RTV 900
   / Strange fan and alternator problem on our RTV 900 #1
kubota orange
We had to do a engine swap on our 2003 Kubota RTV 900 because one of our employee's blew the engine up by running it with no oil :ashamed:
Anyway, brand new motor installed, everything is working good except the alternator and electric fan aren't working right. I traced the wiring back to the same switch/relay on the back of the cab and it seems the alt and fan share this relay. I checked the fuses and replaced a blown fuse that controlled the alt, and ran it again for about ten minutes, then another blown fuse. THought maybe a wire was shorting, unpeeled all the wiring harness and found no frayed or suspicious wires. One thing I need to question though, should the wire that leads to the sensor that goes into the waterpump and thermostat housing have 12v power? I was always under the assumption those sensors operated by grounding the circuit when it got to a certain temp?
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2023 Kubota SVL97-2 Compact Track Loader (A55315)
2023 Kubota...
2018 Ford F150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F150 4x4...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
