Strange fan and alternator problem on our RTV 900
   / Strange fan and alternator problem on our RTV 900 #1
kubota orange
We had to do a engine swap on our 2003 Kubota RTV 900 because one of our employee's blew the engine up by running it with no oil :ashamed:
Anyway, brand new motor installed, everything is working good except the alternator and electric fan aren't working right. I traced the wiring back to the same switch/relay on the back of the cab and it seems the alt and fan share this relay. I checked the fuses and replaced a blown fuse that controlled the alt, and ran it again for about ten minutes, then another blown fuse. THought maybe a wire was shorting, unpeeled all the wiring harness and found no frayed or suspicious wires. One thing I need to question though, should the wire that leads to the sensor that goes into the waterpump and thermostat housing have 12v power? I was always under the assumption those sensors operated by grounding the circuit when it got to a certain temp?
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
378749 (A51573)
378749 (A51573)
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
Skid Steer (A51691)
Skid Steer (A51691)
377670 (A51573)
377670 (A51573)
