Strange Engine...
   / Strange Engine...
Engine is a Napier Deltec.
No wonder those government contracts are over the top pricewise. /forums/images/graemlins/smile.gif
   / Strange Engine...
Could it be a two-cycle?
Four-cycle??
Zero-cycle???
One-cycle????
/forums/images/graemlins/crazy.gif
Those engineers needed to get some air that day. (but how could they get their big heads out the door?)
   / Strange Engine... #4
That Deltic engine is very interesting. The engineering is amazing.
   / Strange Engine... #5
I'm gonna speculate on those engines a bit.
IIRC, Napier is/was a European engine manufacurer. The boats were mahogany hulled and built in Norway, according to an Internet posting I found. It's likely the Pentagon spec'd the boats in terms of on-the-water performance and survivability, with maintainability as a distant third. It's likely they required a non-magnetic hull due to concerns over mines. They almost certainly had fuel requirements that said no gasoline. Being on a gasoline powered boat with someone shooting incendiary/explosive ordinance at you is not at the top of anyone's want-to-do list.
All of this meant getting high performance using some sort of a diesel power plant. Diesels are comparatively slow turning engines, due in part to starting and stopping those heavy pistons at each end of a relatively long stroke. It looks like some engine designer had the bright idea of using two opposing short stroke pistons, instead of one long stroke piston and a cylinder head in order to form the combustion chamber. That would let the engine turn higher RPMs, which would have allowed the designers to crank out additional power.
These beasts reportedly put out 3200 HP, so it seems to have worked.
Although the engine is called a Deltec, probably because of its delta shape, it appears to actually be a V design--albeit a very unusual V.
Again, all speculation on my part. Feel free to pick it apart. /forums/images/graemlins/smile.gif
   / Strange Engine... #6
That engine has to be the most amazing thing I've seen since I sat through a detailed explanation of the Merlin.
   / Strange Engine...
</font><font color="blue" class="small">( Again, all speculation on my part. Feel free to pick it apart. )</font>
SnowRidge,
I'm not going to pick it apart, after all, your explanation sounds quite reasonable.
Funny thing is, I always thought simple wins the race, especially when speaking in terms of military equipment. But then, this was Vietnam, and simplicity had been put back on the shelf somewhere.
Here's another odd ball engine: <font color="green">The VW "W" Engine</font>
   / Strange Engine...
By golly, I think I've figured it out. (at least the reasoning behind it)
<font color="red">You can't blow a head gasket without heads!</font>
/forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
   / Strange Engine... #9
<font color="blue"> (You can't blow a head gasket without heads!) </font>
Yeah, but duck when the pan gasket goes. /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
2835 (A54757)
2835 (A54757)
500LB Livestock Galvanized Creep Feeder (A55218)
500LB Livestock...
2012 Dodge Ram 5500 Chipper Truck (A52377)
2012 Dodge Ram...
2020 FREIGHTLINER M2 106 26' BOX TRUCK (A54607)
2020 FREIGHTLINER...
UNUSED LANDHONOR LHR-BLC1106 TOOL CART (A54757)
UNUSED LANDHONOR...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
