Rake Straightening/Re-aligning Rake Tines
   / Straightening/Re-aligning Rake Tines #11
Egon said:
Now we are hoping it has not exceeded the yield strength when bending are we not?:D :D
By definition, bending exceeds yield strength. We are hoping not to exceed ductility.:)
larry
   / Straightening/Re-aligning Rake Tines #13
Egon said:
Now that is a new one me. I need more clarification.:confused: :confused: :confused:
Consider the distinction between bending, where give in the metal results in plastic compression/extension [yield around the neutral axis/center] and a new shape, and flex where the metal performs elastically. Yield and bending go together.
larry
larry
Ok Larry...thanks for the college degree. Now back to fixing the problem. Do I replace or keep trying your "yield around the nuetral axis/center?" :)
I was able to get both tines another 1/2+ inch closer to the rest with a super-sized crescent wrench, so it works, but I'd like to get it there some more. I think I'll try get a piece of pipe and work it some more.
   / Straightening/Re-aligning Rake Tines #15
Use some heat to lessen the chance of breaking them. To avoid changing the temper you need to stay well below red temperature. 6-800F is ok. To gage this, shine the metal, then heat with a propane torch until the silver surface color changes to straw brown and then blue. Do the bend at blue. Itll be easier to bend and less chance of breaking.
larry
   / Straightening/Re-aligning Rake Tines #17
Larry,
I can't seem to find replacement tines for my 3/4" so I must try to straighten the bent ones. Should I quinch after straighting at blue temp or just leave alone to cool slowly? Any advice on where to get 3/4" tines or how to make? I have 6 broken, and would like to replace.
Thanks,
Neil
   / Straightening/Re-aligning Rake Tines #18
Neil L said:
Larry,
Thanks,
Neil
Just let it cool slowly. Blue should not affect temper. As for replacement tines, I have a York brand rake and Im not sure I can even get tines for it any more. I bought some about 8yrs ago, but Im out. Id do an internet search if I were you. If yours arent directly available there are probably some out there you can adapt. I havnt explored the possibility yet, but it is possible a leaf spring specialty house may be able to help.
larry
   / Straightening/Re-aligning Rake Tines #19
   / Straightening/Re-aligning Rake Tines #20
When I first bought my rake, I figured if you broke a tine, you could just pick up the piece and weld it back. Well, in real life it is not that way. The metal is much like the metal in the leaf springs on your car. When a tine breaks, it breaks in several pieces, not just in half. Those small pieces can fly quite a ways from where it broke, too. That's some pretty brittle metal. Welding won't work very well, even if you do find all the pieces. It's good to have a few spare tines in the workshop. When I am straightening tines back to their original positions, with that kind of brittle metal, I always wear my safety glasses...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
golf cart (A55787)
golf cart (A55787)
GODWIN (INOPERABLE) 3,500 PSI HYD. POWER PACK (A55745)
GODWIN...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
