Straightening Bucket Edge?
   / Straightening Bucket Edge? #1
RedNeckGeek
Super Member
Butte County & Orcutt, California
Kubota M62, Kubota L3240D HST (SOLD!), Kubota RTV900
Anybody have suggestions for straightening a bent bucket edge? Apparently the previous owner was using it to remove stumps and rocks (he also ripped off the top hydraulic cylinder mounts). I've tried using screw type chain binders but wasn't strong enough to make it move. Thought about flame straightening, but wasn't sure what pattern would work best. I just thought this isn't the first time a bucket has been damaged like this and there might be a simple solution.
Thanks in advance,
Scot
   / Straightening Bucket Edge? #2
I've straightened mine before using a hydraulic pull back ram and chains. I'm using a 10 ton Harbor Freight portable pump.
   / Straightening Bucket Edge? #3
Heat works great... when the bend is concentrated in one small area. When spread over a larger area than an ox/act torch can heat up evenly, you might be better off bending cold... but that takes a lot more force to do.
   / Straightening Bucket Edge? #5
Turn the bucket upside down, put a jack on the high spot, loop a chain under the outside edges. Bend it a little past straight and let it spring back. Keep going a little farther until it springs back straight. :thumbsup:
That is how I straightened my bent box blade.
   / Straightening Bucket Edge? #6
Previous owner of my L4200 had moved a lot of round bales with a spike bolted to the bucket so it had noticeable smile in it.
I tried numerous methods that failed but when I had a local welder over for some work he said he could straighten it.
It wasn't just the front edge either the bottom was bowed as well.
Using quite a bit of heat and some well placed blows with a sledge hammer he did, its completely straight now.
The key seemed to be knowing just where to heat it and just where to hit it.
Took him about 30 minutes, but would have taken me much longer even if I'd had the torch.
   / Straightening Bucket Edge? #7
Heat and a big hammer was what was used to get rid of my bucket smile.
Gave it a try this morning, and while I was able to get the edge to move about an inch below flat, it sprang back to just about where it started. I only had a 2 ton bottle jack and I could feel the over pressure valve releasing, so I'll see if I can round up a bigger jack and try again. The log splitter idea looks interesting, too, and I think the bucket will just fit, so that's another possibility.
Thanks for all the ideas!
To close this one off, I had to admit defeat after trying both a 20 ton bottle jack, and using the backhoe of a neighbor's giant CAT. The tractor that came with the bucket is for sale, and if they want the old bucket, it's theirs for the taking.
   / Straightening Bucket Edge? #10
I am not one of them, but there are people out there (machinists/welders) that know how to heat-straighten metal.
I've watched a man heat strighten bent, 4'', 5'' thick crankshafts years ago several times.
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
2007 FORD F-150XL TRITON TRUCK (A54756)
2007 FORD F-150XL...
2025 TMA Attenuator Truck (A52377)
2025 TMA...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
