Straight water in tires?
   / Straight water in tires? #1
pretendfarmer
WA
John Deere 790
I recently bought a used John Deere 790. The tires were filled with liquid which the owner said was water. I emptied some of it and it indeed looks like dirty water. To me this would ruin the rims. What should I do?
   / Straight water in tires? #2
Ours have tubes? You sure you don't? Probably has anti fre3ze in them too. Squirt some in a bottle and use an antifreeze tester...
   / Straight water in tires? #3
If your tyres have tubes in then it won't be a problem.
How cold does it get where you are? Water ballast can freeze if it gets cold enough.
I was warm (-5 Celcius)enough not to have freezing issues on mine.
   / Straight water in tires? #4
In WA I would be hard pressed to not run some type of antifreeze in the rear tires. I suggest - have the "liquid" tested. If it is plain water - drain - reinstall RV antifreeze, RimGuard, methanol or the like.
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
Swict 10' Fork Extensions (A50121)
Swict 10' Fork...
Chevy 2500 Pickup (RUNS) (TITLE) (A50774)
Chevy 2500 Pickup...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
Case-IH 580 Super N (A50120)
Case-IH 580 Super...
2013 Peterbilt T/A Heil 28Yd Side Loader Garbage Truck (A50323)
2013 Peterbilt T/A...
