Straight water in tires?
   / Straight water in tires? #1
pretendfarmer
WA
John Deere 790
I recently bought a used John Deere 790. The tires were filled with liquid which the owner said was water. I emptied some of it and it indeed looks like dirty water. To me this would ruin the rims. What should I do?
   / Straight water in tires? #2
Ours have tubes? You sure you don't? Probably has anti fre3ze in them too. Squirt some in a bottle and use an antifreeze tester...
   / Straight water in tires? #3
If your tyres have tubes in then it won't be a problem.
How cold does it get where you are? Water ballast can freeze if it gets cold enough.
I was warm (-5 Celcius)enough not to have freezing issues on mine.
   / Straight water in tires? #4
In WA I would be hard pressed to not run some type of antifreeze in the rear tires. I suggest - have the "liquid" tested. If it is plain water - drain - reinstall RV antifreeze, RimGuard, methanol or the like.
2003 Ford E-350 16ft Box Truck (A50323)
2003 Ford E-350...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2018 FORD F-150 XL CREW CAB (A51406)
2018 FORD F-150 XL...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
Payment Terms (MUST READ) (A50774)
Payment Terms...
