Straight Posts
/ Straight Posts #1
TomPenny
Royse City Texas
2001 B7500
I couldn't find the old threas so heres a new one.
I got 1000 feet of fence i'm putting in and here is about 400 feet on one side.
My camera phone is pretty crappy so the pic doesn't do it justice.
/ Straight Posts #2
That looks real nice Tom!
When you finish that, come on over to Ladonia and do 9600 feet more. :D
Are you using a 3 point PHD?
I just finished placing some 6" post with a 12" auger, most of the other post will be 4" or 5", so I was thinking of getting a 6 or 8" auger to finish with.
/ Straight Posts #3
Tom, I've never been able to get pictures that good with my camera phone, and I'm not all sure I could fence posts set that straight. Just what method did you use to keep them straight? A string, just line of sight, or what?
And I might find the answer if I read the following threads:
A fenceman can fence anything, almost....
Doing fences Harv style!
Fenceman doing what fencemen do these days
I'm guessing it might be the second thread. Anyway, looks like you've done a good job.
/ Straight Posts #5
Bird,
On my place for cattle fencing, I just set the corner/end posts and run the first wire from corner/end to corner/end and use that first wire as my "string".
Works for me and the cows don't mind if it is slightly off. Here is about a 1000 foot run I'm working on right now and you can see the first wire and the line of posts can't be seen very far because they are directly in line.
/ Straight Posts
I used my Kubota with a 8" auger. For this job I decided to rent a Prodigy from Home Depot. It had been so long since I'd put up a fence, I had in my mind that it would be quicker because of the skid steer and downward hydraulics. Well fortunately for me it had a major fluid leak so I took it back and just used my Kubota. That thing works fine. Every now and then you get a place where the auger just wont go down. I stand up on the auger pole and push against the ROP using legs and back. I know it sound stupid but I'm careful and I not going to fall into the PTO.
Anyway I make my marks on the ground using a string. I know I know Harv, doesn't use strings but Harv ain't here. :)
So after that I set my end posts. I sorta use a combination of string and eye to line them up. Harv once told me something that I'll always remember. Even if you use a string, you still end up looking at it and checking it with your eye and if it's off you'll see it.
That is so true. I just take my time and line 'em up.
As people drive by this job there are 3 areas where you can see down a fence line. I get a lot of complements on how straight they are. Some have said they've never seen posts so straight. Oh well I guess I'm good.
Not that good though. I still can't imagine setting them for height. I wish I could notch the posts and set. Who's dime am I going to try that on?
I don't do many pipe rail fences. This one is down the road so I could not turn it down.
tp
/ Straight Posts #8
Whew, famous last words?:D You're a lot more dare devil than I am.:D A neighbor had an old post hole digger and it sometimes wouldn't go down, so we welded a piece of pipe onto the auger boom, then would stick a slightly smaller diameter pipe into it so we could add weight 3' or 4' behind the auger. He happened to have two 75 pound sash weights that worked very well.
/ Straight Posts
I'm putting the top rail on now and all this pretty work goes to pot. Thats because I'm putting up the woven wire and there is a lot of contour to follow. No matter how I try to gradually follow the grade it still looks hilly especially before the wire fence is on.
For this Guy I've already done his front and side landscape and irrigation that was last year.
This year I did his outdoor kitchen, water fall now the fence.
Left to go is Gate/operator, Landscape around the new pool landscape and irrigation. I like ole' craig.
/ Straight Posts
You know its funny about the leverage on the boom. I do you that for the slightly tough ones. But sometimes in the hard clay around here even that doesn't work. Or maybe I don't weigh enough. But when I get up on the boom and use the strengh of legs and back it works really good.
It just sounds a lot worse than it is and I'm pretty nimble.
(kids don't try this at home)
/ Straight Posts #11
I sounds dangerous BECAUSE IT IS!!!, I never forget the story my emergency room nurse wife tells about the guy they brought in who got his pants caught in a PHD. He lost his sack ( not the kind of sack you get at the grocery store)
Think about that next time you're up on top of an operating PHD!!! Be safe.
Jack
/ Straight Posts #12
I ripped the shirt of a friend of mine who was leaning on the PHD for me. We were being careful too.
His shirt barely touched the PTO drive shaft and before I could blink, it ripped it almost completely off him. Good thing he was 6' 5" and close to 300lb. If he had been a small guy, it would have pulled him in.
Be careful out there.
/ Straight Posts
It was highly inappropreiate for me to post that statement.
Using equipment in an unsafe manner kills or injures people everyday and many of them know better. Worse yet this forum attracts people who are new to using equipment so to expose anyone to ideas that are totally against any acceptable safety guidelines is unacceptable.
I would never use a PTO implement with out the safety sleeve in place. As a matter of fact I'm due a new one since mine is starting to be discolored indicating decay.
I would never get near the PTO shaft or the auger while running. Loose clothing is a major culpret.
I never attach anything to the PTO with the engine running.
Climbing on top of the boom requires careful skill and balance that clearly exceeds most peoples capabilities.
The bottom line is you should never dismount the tractor with the engine running while using any PTO implement and do not operate the PTO without a sleeve on the shaft.
/ Straight Posts #14
Tom,
Looks real nice. I'm always impressed by a nice straight fenceline and the skill it takes to get it that way!!!! Please keep posting pics as it's always fun to see it come together, and the finished project.
Eddie
2015 CATERPILLAR 336FL EXCAVATOR (A65053)
2015 CATERPILLAR...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
300# SPIN SPREADER, 3PT (A64278)
300# SPIN...
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
