storm water drainage pipes?
   / storm water drainage pipes? #1
L_Nicholson
Madison, Indiana
1998 JD 4400
I was wondering how wide I need to make a drive so a tractor and square baler can cross a ditch. I need to make 2 ditch crossings so the farmer that is haying next year can get equipment over the ditches easily.
The pipes come in 20' sections and I was thinking 10' might not be enough space.
Thanks for any help.
Lee
   / storm water drainage pipes? #2
I bought a 12 inch x 24 ft culvert for my trail and cut it in half. The two 12 foot sections work pretty good for this.
Eddie
   / storm water drainage pipes? #3
Depends how deep the ditch and diameter of the culvert as to what width you end up with when finished. Assuming your not building a head wall at each end.
About the only way to maintain the whole 10 feet is to build headwals on each end of the culvert. You can do that easily though by dry stacking bags of Sacrete.( I think Eddie did some this way with nice results) Ask your neighbor if 10 feet is wide enough for the equipment he will be using.
Sincerely, Dirtworksequip
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2004 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2004 V.E...
2015 KENWORTH T660 SLEEPER TRUCK (A50854)
2015 KENWORTH T660...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2011 MAGNUM PRODUCTS 35KW GENERATOR (A50854)
2011 MAGNUM...
