Storing power equipment for the winter
   / Storing power equipment for the winter #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
During the past 40 years every time I have prepared a 4 cycle engine for winter storage, be it a mower, tiller, etc. I have always removed the spark plug and squirted oil into the cylinder, then replaced the plug and pulled the starter cord a few times. Still, I wonder...what with the improved engines and oils today, is such a step really necessary?
   / Storing power equipment for the winter #2
I never have done that on my push lawnmowers and after 15 years of yearly oil change it was smoking a bit at first start up but still cranked on2nd or third pull and never had a carb issue. Stored it with dry fuel tank mostly but then started to put up with fuel in it treated with stabil. For my riding mowers, I double treat the gas (all my gas is non-ethanol and treated with Stabil when I get it home) and park them in enclosed garage. They start right up in spring time.
Doesnt hurt to oil fog an engine but if stored in dry area, I dont think its needed.
   / Storing power equipment for the winter #3
I do exactly this for my jet skis, in addition to adding antifreeze in the cooling system, but i have never thought to do this with the other equipment.
My pre-winter tasks have always been to change all the fuel, oil, spark plugs and clean all the filters on everything that isnt to be used till next year. I then fill all fuel tanks with ethanol free premium fuel with marine grade sta-bil added.
For the past 2 winters that ive added the sta-bil and non- ethanol fuel, i have no longer had engine problems come summer. In the past, i had to deal with clogged carbs all the time. dont get me started on ethanol..........
I was told by a few mechanics not to leave the fuel tanks empty or they could cause some dry-out issues. not sure, if this is true, but so far no dry out issues by leaving them full.
it might be easier to heat my shop all winter :cool2:
After several negative experiences with using fuel stabilizer in small engine fuel systems, I now drain the tanks and the carb float bowls. Removing the float bowls also enables me to clean out any gunk in the bowl and I have been draining fuel systems for 15 years now with no negative effects...and my oldest push mower is a 1990 model.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
Unused Delta Crash...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2000 GROVE RT640E MOBILE CRANE (A51406)
2000 GROVE RT640E...
