storing a rotary cutter vertically
   / storing a rotary cutter vertically #1
jrm21
NY
GC1705
I have a 4ft rotary cutter that I use with my MF GC1705. The cutter is big, heavy and takes up quite a bit of room when not being used.
Have seen that some people store it vertically. Trying to figure out how to do this. I'm in the process of building a small barn and plan to use one or two stalls for storage of my gear and implements. Space is always at a premium and stacking or going vertical will really save some room.
Any ideas? I am guessing a chain lift would work.
Where/how to attach it to the cutter? Which end to lift it from? How to mount it from above to safely support the weight? Will vertical storage cause a problem with the grease/oil in the gearbox and, if so, how to avoid or correct for that?
Seems like it should be a simple concept. With the weight of the implement, I want to make sure I don't break the building or cutter, and certainly don't want to cause a safety problem.
Would love some ideas and suggestions.
   / storing a rotary cutter vertically #2
Good questions as I would like to do the same.
   / storing a rotary cutter vertically #3
Dealers do it:
Folding mowers do it:
   / storing a rotary cutter vertically #4
I don't know how much head room that you have in your barn, but if you can lift it with your FEL (you do have an FEL don't you?), you could just lift it by the tail wheel and carry it to the back wall and let it down. For safeties sake, use something to secure it to the wall so it doesn't move after you unhook it.
Yes, I have an FEL. Never thought of lifting the cutter with that.
So I would come around the back of the unit. Then "scoop" the FEL under the wheel, tilt and lift? The wheel and arm are strong enough to support the entire unit? It almost seems like the wheel would snap right off.
Just having trouble visualizing the process. I am pretty new to tractors in general so my imagination is very limited on ways to use the FEL. Could you spell it out for me in term a beginner could understand?
   / storing a rotary cutter vertically #6
No you would not scoop, use nylon strap or chain to secure it to you grab hooks on your bucket. Oh you don't have grab hooks, Ken who is on the forum can help with that. Or if you have a a set of forks for your fel if you have a ssqa attachment on your loader. it makes life easier.
DevilDog
I have tow straps that could easily handle the weight. My bucket has a single tow hook.
Here is a pic of the cutter I have. Where do I loop the strap for lifting? Am I strapping to the rear wheel arm? Do I look through the bracket for that arm?
   / storing a rotary cutter vertically #8
I'd flip the tail wheel and arm forward on top of the gear box then use a strap or chain on the two bolts in rear of the bracket to lift it by.
   / storing a rotary cutter vertically #9
You're new to tractors, aren't you? :laughing:
Beyond new. I'm at the stage where I'm just trying to not break anything - including myself. :)
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2023 EAST TEXAS TRAILER (A52472)
2023 EAST TEXAS...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52748)
2017 Ram 5500...
2013 CHEVROLET SILVERADO 1500 (A52472)
2013 CHEVROLET...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
