Storing 3 pt post hole digger
   / Storing 3 pt post hole digger #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I recently used my PHD for the first time in a few years. It has been "stored" outside just laying on the ground. I would like to see some pictures of how you guys store yours. By the way, I added "3 pt" in my title because I kinda figure some wise*** would post a pic of a hand held one hanging on the wall...hahaha
I know there have been numerous threads about this subject, and I also know one of the first responses I get is going to be "search and you will find numerous threads." I find no harm in starting a new one, and if it offends you, I apologize. I don't think it is bad to rehash old subjects.
   / Storing 3 pt post hole digger #2
Most I've seen, that were not just laying on the ground, were upright in a hole of their own digging. Some were tied to a barn post or fence post. Others (probably the bad ones) were hung from gallows.
Bruce
   / Storing 3 pt post hole digger #3
We had ours in a hole that was dug with it then just unhooked, it works but it will eventually rust a lot being as how you probably won't be using it much and the water getting in the hole. My dad had one with a complicated hanging device bolted to a wall with a top link, I would highly suggest not doing that way. If you think it is hard to hook one up by your self off the ground you should have tried to get it out of that contraption, lol.
   / Storing 3 pt post hole digger #4
The only one I've dealt with is stored standing up and tied to a couple of posts that hold the shed up. Was like that before I knew anything about it and hasn't been touched in probably 5 years. If you're strong enough you could hook it up by yourself but it really requires 2 people.
   / Storing 3 pt post hole digger #5
I've honestly found the best method for me is to drop the auger bit and driveshaft off the unit. Pulling the shear bolt on the driveshaft and the two bolts holding the auger bit on takes only a couple minutes. I leave the bolts in the bit and shaft when storing so they don't get lost. It is much easier to handle with just the gearbox and frame to mount/dismount on the 3 point. It also stores a lot easier, in a lot more places.
   / Storing 3 pt post hole digger #6
Right now mine is stored outside. It is sitting on boards. I also welded a lift point on the top so I could hang it from a tree branch.
Box blade and most other attachments sit on pallets.
That was pretty much my solution when I finished using it last week. I remember from old threads some pretty ingenious storage racks/hanging devices. One fairly simple one involved two 4x4s stood up in the ground with a top cross member to hang the PHD on. I intended to make one but never got around to it.
   / Storing 3 pt post hole digger #8
Lean it up against/tie it to a tree or heavy fence post. I also like the "hole" idea.
   / Storing 3 pt post hole digger #9
Drill hole for easy 3pt. hitch line up,cover/ from tarp from weather.
   / Storing 3 pt post hole digger #10
I set the auger on a piece of wood back up to a pole in the pole barn and tie it off with some rope unhook and lower the arms down. Done it that way for 12 years, out of the weather and still looks like new.
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
2012 PETERBILT 388 (A50854)
2012 PETERBILT 388...
TOP HAT TRAILER MFG. LIGHT PLANT TRAILER (A50854)
TOP HAT TRAILER...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
