Store chains in a coffee can
/ Store chains in a coffee can #1
Knotbored
Sedro-Woolley, WA
Kabota
I was pleasantly suprised to find my 14' chains fit into a coffee can (all but the ends.) I used heavy bailing wire to tie the cans onto my box scraper, slip the chain ends onto the frame and off I go.
I always carry two chains on the tractor because my main need is brush and limb clearing. Befor I just wound the chains around the box scraper frame and the chains would vibrate loose, get hung up on brush and were tangled and hard to get untangled. Now I can load and unload chains in 10 seconds. I need to punch a few holes to drain rain from the bottoms.
I have seen several methods to store chains, but none simpler then this.
/ Store chains in a coffee can #2
Good Afternoon Knotbored,
Wow that sounds like a great idea !
I wouldnt think that my chains that go on my Massey would even fit in a coffee can. My rear tires are 13.6 x 24", but that would be a good idea if they would.
What size rears are on your Kubota, just curious on the size ?
Opps just reread your post, I see your talkin about regular chains, not tire chains, sorry about that !
I keep my pulling chain wrapped around my counter weight, since thats what we are talking about !
/ Store chains in a coffee can #3
I think he ment drag chains not tire chains....but still a good idea for tire chains.:D
/ Store chains in a coffee can #4
A piece of 4" ABS pipe with a cap mounted to the loader bracket is what I store a couple of chains in --- but I believe a large coffee can will now be used for some of the short "sling" pieces I have;)
/ Store chains in a coffee can #5
The only thing I put into a coffee can is the stuff I want rust on. :rolleyes:
/ Store chains in a coffee can #6
I don't usually carry chains on the tractor except for job specific useage. However, to keep them in an orderly fashion, I put them in a five gallon bucket with the hooks hung on the rim.
I paint the hooks with odds and ends of almost empty spray paint cans to ID them.
/ Store chains in a coffee can #7
I use a 5 Gallon bucket to store my 4 tie down chains. Chains go in and hooks hang on the bucket edge. I tried more than 4 chains in the bucket but it gets too heavy to lift.
/ Store chains in a coffee can #8
I don't know whether everyone understood that or not, but you're sure right.:D Even with drain holes in the bottom of the can, it seems that anything you store there WILL rust.:D
/ Store chains in a coffee can #9
The part I understand is that if 14' of chain fits in a coffee can, it's either small chain or coffee comes in larger cans there than here.
/ Store chains in a coffee can #10
Must be an older can sold before the manufacturers started reducing the size rather than raise the price, lol!
Yes its the older "almost 3#" size can-and I believe the chain is 5/16.
By the way-HF has cheap end hooks for 1/4" and for 3/8" chains, but not for the 5/16" truckers chains I almost always find at garage sales.
Painting the ends sounds like a great idea-I typicly spend more time searching for chains when I set them aside then I do working.
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
2022 EZ-GO ELITE...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
1059 (A63291)
1059 (A63291)
2020 INTERNATIONAL LT625 SLEEPER (A59911)
2020 INTERNATIONAL...
