Chipper Stop The Burn!! (New Jimna Chipper)
   / Stop The Burn!! (New Jimna Chipper) #61
I sell alot of woodchippers (in the hundreds) I asked the factory and they said that Jinma does not make a 8" woodchipper, now that being said somebody might but not Jinma.I have also asked them about making a scaled down 4" model and to get the weight down to 500-550lbs.We will see what they come up with.Thanks Gordon21 for the plug,we try to keep the woodchippers in stock plus all of the replacement parts.
Tommy
Affordable Tractor Sales
   / Stop The Burn!! (New Jimna Chipper) #63
The ad for the 8" model says it has a 24", 175lb flywheel...but I think that's the same flywheel on my 6" model.:confused: It also lists the 8" model with a weight of 800lbs...doesn't my 6" model weigh 900lbs? double:confused: :confused:
All in all, I bet I could probably force an 8" or even 10" log into mine as far as the feed roller opening is concerned.:eek:
Maybe I better not...:rolleyes:
   / Stop The Burn!! (New Jimna Chipper) #64
I'm confused also, the 6" chipper has a 175lb flywheel and 2-sets of 10" blades? I would have them send you the specs on both to compare them.
The factory would have no reason not to tell me the truth
Tommy
   / Stop The Burn!! (New Jimna Chipper) #65
Not sure who Goss in Jasper, GA is a dealer for, but I have found them to be great to deal with and fair prices. 800-207-0523.
I think I'd want way more than 20HP to chip 8" of tree. My 35 pto hp tractor struggles on 5' cedar and 3.5" blackjack oaks. I haven't even considered putting my 6" chipper on my 20pto HP tractor.
   / Stop The Burn!! (New Jimna Chipper) #67
My 30.5 hp occasionally shudders a bit, but only when chipping dense hardwood. SmithLa's profile shows he owns a 40hp Mahindra, so I think his machine could handle the 8" chipper. With a 20 hp (tractor, not PTO hp), I think I'd burn everything over 4" thick, unless it was kinda rotten ;).
The idea was that Jimna states 18-70 hp, thus giving folks with a small tractor the idea it will work with their tractor.
   / Stop The Burn!! (New Jimna Chipper) #69
I updated my profile, I now own a Mahindra 6000 4WD, and it is rated at 59 hp. It probably would handle anything I throw at it.
I'm supposed to test drive a Wallenstein BX62 in a few days. I'm taking a few of these darn pines to throw at it. It costs $4K but seems to be well built as far as I can tell. Can't find anybody around here to test the Jinma, at least not yet.
I only live about 40 miles from Goss Tractor in Jasper, but he has been pricey on everthing I have ever looked at. I may stop in when I go over to Calhoun to test drive the Wallenstein.
Thanks,
   / Stop The Burn!! (New Jimna Chipper) #70
The Jinma woodchipper will save you a couple of grand and do everything the other chipper will do,I wish we were closer so you could try one.We had a customer bring 2-treated 4x6 posts and feed them thru a 6" Jinma chipper
with a 25 hp tractor and it never missed a beat.If your set on the wallenstein chipper then get it,I understand not seeing one before you buy.If you do a search on here for the Jinma Woodchippers will will see alot of positive comments about them,parts for the Jinma woodchipper are a phone call away,we stock All the replacement parts and new blades.The blades are reversable to get double the useage and replacements are only $ 95.00 a set
You have to decide whats right for you.
Tommy
CAT Skid Steer (A50322)
CAT Skid Steer...
2021 Kubota SVL75-2 Track Loader (A55314)
2021 Kubota...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
2014 INTERNATIONAL PROSTAR+ (A55745)
2014 INTERNATIONAL...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
New Holland T2420 (A53317)
New Holland T2420...
