Stock Remotes ( L3830 ), quick disconnect?
   / Stock Remotes ( L3830 ), quick disconnect? #1
goneandbrokeit
Does anyone have the stock remote set up on a Grand L? I recently hadthe T&T installed. I will need to set up the BH90 to dig a ditch and while I see where I expect the disconnect to be, I do not see the release.
I am familiar with the quick disconnects for the loader but the mechanism does not appear to be the same on this set up. I must be missing something obvious, can anyone offer suggestions.
Attached is a picture of the assembly. Thanks for any help.
   / Stock Remotes ( L3830 ), quick disconnect? #2
To run the backhoe from one of the remotes you will have to tie one of the remote levers open using a bungie cord or some other simialr method. Simply connect a hose from the backhoe inlet to a remote port and a hose from the backhoe outlet to the other matching remote port. Active the remote lever making sure the flow is correct. If it's not then move the lever in the other direction. Tie the lever open. You are now set to dig.
Hi Mad,
I do not need to hook my back hoe up to the remotes, I have the power beyond. My question is about disconnecting the T&T cylinders from the "six-pack" pictured in the attachement.
For my loader ( and power beyond ) there is a ring the gets pulled back that releases the quick connect. I am looking for the release mechanism in this setup. Thanks.
Len.
   / Stock Remotes ( L3830 ), quick disconnect? #4
Oh, OK, just pull the hoses. It'll come out.
I have a setup similar on my B3030. Just pull the hose and it'll pop out. To connect a hose just push it in the connector.
Ok, thanks I considered this, but did not want to force it. I will give it try
   / Stock Remotes ( L3830 ), quick disconnect? #6
Just push in on the hoses to connect and pull to release. The housing for the remotes holds the outside of the coupler.
It threw me for a loop on my L3430 also, easy once you know how.
ksmmoto
   / Stock Remotes ( L3830 ), quick disconnect? #7
Make sure there is no pressure on the line. Sometimes I really have to jerk hard to get the remotes disconnected.
   / Stock Remotes ( L3830 ), quick disconnect? #8
goneandbrokeit said:
Hi Mad,
Sorry, I thought you were asking something else. The other guys have it right.
2022 John Deere 6135E (A50120)
2022 John Deere...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2020 Nissan Altima Sedan (A50324)
2020 Nissan Altima...
