Stipping a B250 gearbox.
   / Stipping a B250 gearbox. #1
zonta223
Platinum Member
Adelaide South Australia
Foton FT404, International 444 with forklift, International B250, Kubota L2000DT, Truck converted to all terrain forklift and lots of other junk
Looking for some information on removing the gearbox/diff assembly from the tractor.
Is it possible to remove the gearbox/diff assembly and leave the clutch assembly and bell housing still connected to the tractor?
Any help or guidance appreciated.
Goodness could not even spell stripping lol
   / Stipping a B250 gearbox. #2
If I am correct you needs to split at the clutch and remove a c-clip from the bottomshaftplug. Then remove that plug and a c-clip from the bottom shaft s tip.Now remove the pto shaft from the back and the pto selector from the leftside.
   / Stipping a B250 gearbox. #3
I think you may be correct for the B275 which has a dual clutch but my B250 only has a single clutch.
And both have some gears and shafts to drive the PTO
I'm sorry but you are wrong.
The gearbox on a single clutch plate B250 can be easily split from the clutch bell housing. leaving the clutch bell housing and clutch connected to the engine.
There are 2 external bolts and 6 internal accessible after you remove the inspection plate.
Remove these bolts and the gearbox/diff can be removed.
2006 Husqvarna YTH2148B Riding Mower (A51694)
2006 Husqvarna...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
Duetz Power Unit (A50120)
Duetz Power Unit...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
