still blowing white smoke
   / still blowing white smoke #1
jpig
Tennessee
jd 5205
I have a new 5205 with 28 hours on it. It smokes at start up for a few minutes. After it gets up to temp. all is well. It seems to run fine. If I shut it off and let it set for about five minutes and start it again it starts just fine, but when I accelerate it starts bellowing white smoke acts like its running on 2 cylinders. Does this for about 30 seconds and then clears up and runs fine. All of this is with no load. Help!
   / still blowing white smoke #2
White smoke is usually unburned fuel . Call the dealer and make them repair it .Could be timing pump or ? At 28 hours total time there is no excuse for this happening on a new unit . And make them give you a new hat too for your problems ! /forums/images/graemlins/wink.gif
Allen
   / still blowing white smoke #3
My local dealer had a simular problem with a 5000 series tractor, They changed out the turbo and a bunch of other parts. Turned out to be injectors.
   / still blowing white smoke #4
You have had some good suggestions aready, A couple of other things it may be is, inoperative preheater, coolant leak into the cyl. , and fuel quality. Because of your indication it runs like it is on 2 cyl and then clears up after a short time my hunch is an injector.
Thanks for the info. I'll call the dealer and set up an appointment. I'll bet it's the injectors.
   / still blowing white smoke #6
So how about an update? What did the dealer do?
2020 JOHN DEERE 5125R LOT NUMBER 24 (A53084)
2020 JOHN DEERE...
GS-3246 MAN LIFT (A52472)
GS-3246 MAN LIFT...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
