Stihl - weedeater - engine runs erratic
   / Stihl - weedeater - engine runs erratic #1
GaryDG
I have Stihl weedeater. I push the primer button 3 times, put the choke on and pull - it starts right up. I take the choke off and the unit runs as it should. After approximately 5 minutes of normal use the engine starts to oscillate (normal rpm to low rpm to normal rpm) then run as if it wants to die. By constantly depressing and releasing the accelerator lever I can keep the thing running for a while but after about 8 minutes of running erratic it dies.
The only thing I can think of that is causing this is some type of heat related issue - that is once the engine heats up the issue occurs.
   / Stihl - weedeater - engine runs erratic #2
I hope you mixed the fuel correctly .
   / Stihl - weedeater - engine runs erratic #4
Hopefully it is exhaust being plugged, but maybe also do a poor man's compression test: How hard does it pull when cold as compared to how hard does it pull when hot? Or with a gauge if you have one.
If your piston rings are shot, and/or cylinder walls are scored, she might not be making compression, this might be a harder fix.
   / Stihl - weedeater - engine runs erratic #5
First time you've used it this season ?
Issue just show up ?
Did you drain it and run it dry at the end of last season ?
   / Stihl - weedeater - engine runs erratic #6
I had a similar issue... $26 later a new carb fixed the issue. Common problem according to my local stihl dealer. Same issue with a concrete saw at work, new carb, runs like new.
   / Stihl - weedeater - engine runs erratic #7
I had the same problem last year with my FS250. The carb cost more than $26, but it has been running fine ever since-started it up yesterday and used for the first time this year-4 pulls and I was in business.
The dealership I use told me they don't even mess with the carbs on consumer grade Stihls-they just replace them for around the $26 mentioned earlier.
Will
   / Stihl - weedeater - engine runs erratic #8
*grin* The carb on the concrete saw at work (TS420) cost 3x what my lil string trimmer carb did! But same awesome results.
   / Stihl - weedeater - engine runs erratic #9
Blame all the above issues on crap E-gas. You have to stabilize it, drain it or buy ma new carb every year. Thanks Obama....
   / Stihl - weedeater - engine runs erratic #10
The gas issue is why I don't put 'regular' in my cans. Be it saws, weedeaters, lawn mowers, or generator, it will likely sit a while in the can or in the tank... so I buy the better stuff. And the 4wheelers run better on high test too.
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
1272 (A50490)
1272 (A50490)
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
